99v10 Something is wrong PLEASE advice
Please be sure to post up the results. I have changed just about every other single item concerning the cooling system (radiator, water pump, clutch fan, hoses, etc.).
I didn't even think about the collateral effects (misfires, transmission shifting issues - which, btw, when I put in my performance tune - the trans seems to shift not quite right. I suspect the performance tune "enhances" the issue. In fact, as "rough" as the truck runs - it is considerably worse with the performance tune.
Of course, I have the factory tune in the truck until I chase this down.
I just spoke to a mechanic friend of mine who stated if I could reach the CHT w/o removing the intake manifold I should just go ahead and attack it anyway as it removes one more variable.
He stated he has enough 18mm wrenches that I could certainly find one that would work. If nothing else it's still 20x's LESS expensive to buy a wrench and alter it like you did than pay a dealer/mechanic to do this "buy the book".
I'll be watching for an answer Matt, as I'm looking to do mine the following weekend (when I get back on my feet)!!
Thanks guys!
To break it down.
1.) Remove Battery cables. (I do so when ever I work on something electrical just in case)
2.) Remove or loosen alternator enough that you can get sufficient room to get in to the sensor itself.
3.) Once you have sufficient room to get the the sensor then it's time to bend and cut the wrench, I used the 3/4 even though it calls for an 18mm, it didn't fit was snug as I like.
4.)
If you're not sure of the location this is where your sensor is located. (Take note it shows the intake and all removed, you DO NOT have to do this if you have some patience.)
There really isn't much to explain, if you have any questions I will PM you my cell number and try my best to answer them. I've done just about everything imaginable to this truck that you can think of.
I'll try and get out in to the garage tonight and look around all the tools I made for different things and see if I can get a picture of the wrench for you, so you have an idea of what it looks like.
In addition I have my 12-yr old assistant since my hands do not lend themselves to fitting in small spaces!! He is really good at getting to places just like this!!
Thanks!!
Pics of the wrench would be great! I'm thinking an 18mm stubby might do the trick.
It's not hard to find at all.
If you feel like it, make a trip to PA I'd gladly help ya out.
Not totally sure if it has fixed my problem, I read, or was told that it may take a couple drive cycles for things to clear up...Is this TRUE???
However, I just disconnect the battery whenever I'm working on something like this so when I hook it back up I expect it to be reset.
Have you noticed any improvement at all? Did you have to modify a wrench to get in there as FF did??
Btw, I crack up b/c every day that pic changes!! I DID see it the first day when it showed the location of the sensor.
Overall, Matt, was it a hassle for you? Looking to do that this upcoming week.
I'm just realizing, however, that you both have the V-10's... Mine doesn't look like your pic. I would have to go UNDER the crossover tube b/c it's against the manifold (which is plastic!)...
Well post after I try it!!
However, I did have a 19 12-point boxed end offset wrench. I could get it on there but had so little room for a sweep that I couldn't even get it 1/12th of a turn. I did what FF did and heated that wrench, hammered it a few times and my new custom wrench did the job!!
Thanks for my son for helping me with his small hands to get back in there!!
The result: it did NOT fix my problem!! AT ALL!! I was 100% convinced this was the issue to my false overheat!!!
When I called a while back for this part the parts guy at Ford (this guy has been there for a LONG time) stated there are TWO coolant temp sensors on this truck!!! So I need to call tomorrow morning and find out about where the other one is and if they have that part in stock. I believe one is this CHT and I don't remember what he said about the other.
And looking at your photo above, Matt, it looks like you have a secondary coolant sensor next to your thermostat housing!! I have one in the same spot but I added it with my gauge! Yours looks factory.
I am still 100% certain that this IS a false overheat. But in addition my truck is throwing multiple misfires and running like a P.O.S. right now!! BUT....one thing at a time!!
I am growing ever more frustrated with this thing... Things that should be simple are ridiculously complicated. Btw, I saved at LEAST 5 hours of work replacing this sensor (according to the book which states to remove the intake manifold)!!
Did you do this yet?
I have never had a reason to use those wrenches either and if it wasnt for them being on the seat of my other truck that I took to the parts store I would have never either thought of it.
