Rear Diff Cover ?
Old Apr 2, 2011 | 09:03 PM
hosemandc's Avatar
hosemandc
Rear Diff Cover ?
Just bought my 2011 F450 diesel. I had a body shop spray undercoating on. I realized yesterday that they spayed everything including my differential covers. Should I be concerned about the undercoating on my rear diff considering I haul a 16k toy hauler? Will this cause excess heat?
Old Apr 2, 2011 | 09:36 PM
Tom's Avatar
Tom
The aluminum rear finned differential cover was installed in all 6.4L and 6.7L trucks to keep the rear differential cool. These engines make a LOT of power and these differentials can get pretty warm when under load for a long period of time.
I would make an issue of it, I think this could shorten the life of your differential.
Old Apr 2, 2011 | 11:01 PM
kper05's Avatar
kper05
I had figured those fins were there to mimick a processor heatsink on a motherboard.
Good to know I don't have to guess now.
Old Apr 2, 2011 | 11:34 PM
Zmann's Avatar
Zmann
front cover I would be ok with ,, it's steel and would rust just like the older rear covers
if nothing else I would take a grinder with a flap disk and clean off the top of the fins for a nice look
Old Apr 3, 2011 | 01:05 AM
Marauder92V's Avatar
Marauder92V
Mine is not ribbed (3.55 with ELD)! Any idea why that would be the case?
Old Apr 3, 2011 | 01:49 AM
Zmann's Avatar
Zmann
We have not figured out why some are and some are not most are if they are srw's
but don't sweat it they are only 50$ and all the older Sterlings did fine without the new covers
Old Apr 6, 2011 | 02:19 PM
doczenith1's Avatar
doczenith1
I'm pretty sure they stopped using the ribbed covers on SRW trucks built 11/2010 and later. DRW trucks are still getting them. My data doesn't extend past 12/2010 so I don't know if they have switched back or not. Take a look at my spreadsheet and feel free to input your data.
https://spreadsheets.google.com/ccc?...thkey=COfo2fwD
Old Apr 6, 2011 | 02:43 PM
Tom's Avatar
Tom
Looks like you put some time into that spreadsheet, great info!
Old Apr 6, 2011 | 02:49 PM
doczenith1's Avatar
doczenith1
Not really. I just entered my data. All the other stuff was entered by other superduty owners.
Old Apr 7, 2011 | 12:54 AM
maistroyoda's Avatar
maistroyoda
My F350 SRW CC has a build date of 12/10 and has no fins.
Old Apr 7, 2011 | 07:38 AM
amadas350's Avatar
amadas350
the fins have to have air going across them to really help. being on the back side of the differential with limited air flow, i doubt they are as effective as some think. the change from steel to aluminum is the biggest help.
being said, i do not think a thin undercoat cover will retain enough heat to even consider worrying. 07 and older got painted stamped steel covers and have you heard any problems with them? but if it really bugs you, grab something to take it off.
Old Apr 7, 2011 | 06:55 PM
mach8274's Avatar
mach8274
Mine has the finned aluminum cover. I think it's aluminum, looks like aluminum. F250 built 9/10.
Old Apr 7, 2011 | 08:47 PM
azking_Ranch's Avatar
azking_Ranch
Just checked my F350 SRW it doesn't have any fins either
2011 F350 LB SRW KR FX4 Golden Bronze
AZKing_ranch
Old Apr 7, 2011 | 08:51 PM
Big-Sarge's Avatar
Big-Sarge
I had the same thing happen to me, I put some Kerosene on a rag and it rubbed right off.
Old Apr 8, 2011 | 02:48 PM
jaybread's Avatar
jaybread
SRW's starting in MY 2011 have regular stamped steel diff covers.
All MY 2011 F450 and F350 DRW's have finned aluminum covers. Coating the aluminum will reduce the ability to transfer heat.
Whether or not this will damage anything depends on the heat loading of the rear end.
If Ford determined that DRW's could tow at max across Death Valley in the summer without the finned heat dissipating cover, they wouldn't spend the money to put it on.
