Rear Disc Conversion
Old Apr 2, 2011 | 06:38 PM
1979F350/460's Avatar
1979F350/460
Exclamation Rear Disc Conversion
So I'm in the process of the Rear disc conversion on a DANA 60 in my F350 4X4.
The problem I am having is with the wheel studs. The New ones from Dorman will not keep the rotor to the back side of the hub. Has anyone else had this problem? If I reuse the old studs it will hold but the new ones will not. My old studs are pretty messed up and I have no choice but to replace them. Does anyone know where I can find the Ford factory ones? Even a Part number for them?
Old Apr 2, 2011 | 07:37 PM
Rellim51's Avatar
Rellim51
I reused my original studs so I really can't help much. Could you run a die over the original studs and reuse them?
Old May 9, 2011 | 11:01 AM
1979F350/460
Used the 9/16 Stud from a 97 F250 4X4 Worked perfect no drilling nothing!
1979F350/460
Offroad & 4x4
Nov 29, 2010 10:11 AM
1979F350/460
Nov 16, 2010 11:39 AM
1979F350/460
Oct 20, 2010 05:38 PM
Blackwaterforge
Aug 20, 2010 09:20 AM
Jodell
Mar 24, 2009 01:39 PM
