Motor shake
Old Apr 2, 2011 | 04:50 PM
kper05's Avatar
kper05
Motor shake
Before you say anything smart, I know it's a diesel, it shakes.
However, today I started it after a 5 hr soak.
45 seconds after start, I flipped on my 1,400 RPM SEIC so I could get the cab cooled off for passengers.
The whole truck started shaking and it seemed to have trouble getting up to the set 1,400 RPM. Took about double the time is normally takes for SEIC to rev up the motor.
Strong smell of exhaust but nothing I could see.
It's 70 degrees F outside.
Coolant is at max fill line running.
Oil is slightly above max fill line (thank you regen); checked before start.
No leakes while running.
Oil dipstick properly sealed.
Reminded me of a cold 6.0L.
Anything I need to check for?
It never did anything like this when it was 8 degrees F over the winter.
Seems it should be happy with 70 degrees F.
Old Apr 2, 2011 | 04:53 PM
senix's Avatar
senix
EGR valve sticking. That is what comes to mind.
Trash Hauler
6.7L Power Stroke Diesel
13
Dec 7, 2024 11:05 AM
MarkA4
Jan 8, 2015 11:51 PM
andrew1989
16
Sep 22, 2012 03:06 PM
kper05
Oct 6, 2011 08:24 AM
