I was looking at the scanguage2 to hook up to my trucks OBDII port.
But when i looked at the compatibility chart it says it does not work in '96 or '97 ford,gm,or dodge trucks with diesel engines!!
I've read in this forum of other people using the scan guage.
Has anyone else come across this problem? will it still work?
Or should i just call the factory to make sure?
Thanks for the info. that aeroforce interceptor is a much nicer looking unit than the boxy scanguageII.
Just wish it could display more than 2 things at once.But still a much nicer unit..
You can set the Aeroforce gauge up to automatically rotate through 8 different readings. Not the same as all at once but still pretty handy
