Add-A-Leaf Kits????
Old Apr 2, 2011 | 12:01 PM
Aune163rd's Avatar
Aune163rd
Add-A-Leaf Kits????
So Guys whats the key to these things, which ones do I need? My 84 has the stock 5 springs in the rear and 3 in the front (idk why you only need 2). But at any rate, I want to add like 3 or so to it as auxillary ones you bolt on?? I have no idea what these look like or anything so throw some ideas and pictures at me so i get an idea of what i need to buy and what kind of work is involved.
Old Apr 2, 2011 | 01:13 PM
bashby's Avatar
bashby
Are you trying to lift it or increase payload? See the dually conversion thread, there are som options discussed there. https://www.ford-trucks.com/forums/1...to-dually.html
Old Apr 2, 2011 | 01:50 PM
Aune163rd's Avatar
Aune163rd
Im trying to increase payload, but i dont want to convert this to a dually.
Old Apr 2, 2011 | 02:17 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Something like this?
Old Apr 2, 2011 | 02:54 PM
oreocreaming's Avatar
oreocreaming
if you feel like going to a wrecking yard, check for a chevy 3500 dually, they have the same 3 pack that john just posted. and at a wrecking yard you can get em cheap.
Old Apr 2, 2011 | 03:08 PM
bashby's Avatar
bashby
Originally Posted by bashby
I just got an air spring kit from jc whitney for an Excursion. Havent installed it yet but it seems to be made well and from what I've read they work great. I opted for the compressor kit also that comes with a pressure gauge that mounts under the dash and has a switch to turn comp on and a button to bleed pressure. Total cost was +- $425. I think that would be ideal for a removable camper, as adding more leafs is going to make it stiff when empty.
Originally Posted by IDIDieselJohn
At the time I didn't have money for air bags, compressor etc. so this is what I have on my F250. Sure doesn't ride as nice as air bags when loaded, but sure did keep the front wheels of the truck on the ground, and the axle off the frame in the back
Those arfe Timbren "springs", If anyone is wondering. They are popular with the snow plow crowd. Price is right and there's no air lines to leak.
This is what I was talking about in the dually thread. There is a picture of the timbren springs I tried to paste here but I dont think it will work. See post 13 or so in the link I posted above if you wanta see.
Old Apr 2, 2011 | 03:20 PM
oreocreaming
thats a nice block of extra weight payload you can carry. nice cause it doesnt alter the unloaded ride
Old Apr 2, 2011 | 04:31 PM
IDIDieselJohn
Here you go.
Old Apr 2, 2011 | 04:44 PM
Aune163rd's Avatar
Aune163rd
Thanks John, thats what im talking about but ive seen these kits that add 2 or 3 with some brackets bolts around the end of the extra leafs on both sides of the axle. I want a total of 8 springs in the rear on each side, which means adding 3 on both. Cause I have 5 for some reason (IDK FORD THREW THIS TRUCK TOGETHER).
I dont want the second kind your showing with the air ride type thing...idk what they are called haha ! I can carry about 2000 lbs(ton of hay) in the bed and I just want the peace of mind lol. And im not worried about how stiff it will be in the rear when unloaded because I wont be driving this truck unless its loaded, or im going somewhere where it will probably be loaded down with something at some point.
Old Apr 2, 2011 | 04:49 PM
IDIDieselJohn
Those rubbers aren't air ride, there hard empty rubber boots.
My F250 also has the stock 5 leafs in the back, and never bothered adding some, or going air ride, these were alot cheaper than anything else.
Old Apr 2, 2011 | 10:39 PM
85grey's Avatar
85grey
I replaced my springs with stock NEW ones and that raised me up a bunch. Especially
when loaded. The springs are 25 years old remember and they lose some of their spring
just getting new 5 leaf helps alot.
Old Apr 3, 2011 | 10:18 AM
bashby's Avatar
bashby
Here you go.
Vehicle Suspension Kits - Timbren Suspension Enhancement Systems THERES WHO MAKES THEM IF ANYONES INTERESTEED
Old Apr 3, 2011 | 03:54 PM
Aune163rd's Avatar
Aune163rd
well it looks to me like the add a leaf kit is what i am looking for. those rubber boots, we use those on our MRAPs and they break a lot from use. I seen one that had fallen off and half was still there, then again the Caimen weighs some 20+ tons. So unless you guys would recommend the boots over the springs? I honestly how those work or anything. What are they rated for in wieght? And what kind of expierience do you guys have with them?
M-S-G
Mar 2, 2025 10:12 PM
TractorM3
2015 - 2020 F150
Dec 13, 2015 01:13 PM
welbo97
13
Jan 26, 2015 09:39 AM
choate
Jun 30, 2014 02:59 PM
Redneckfordf2502002
63
Dec 8, 2012 11:32 PM
