I bought 3 since I installed the setup a few years ago and now need to buy a few more. Anyone have a good site for a good price on these or a comparable good quality replacement?
HaHa,I know I use the larger of the two or I would have the number. The Deere filter(RE11992) is used on a couple of other engines of mine, so out of convienence they are always sitting on the shelf.
A "charged" filter is one with a dissolving block of Supplemental Cooling Additive" (SCA) in it. It is how the cooling system was (and maybe still is) maintained on big diesel engines that don't use pre-charged coolant (like Ford Gold or Cat EC-1 rated). SCA's help prevent some of the issues plain ol' antifreeze has in a diesel environment, like cavitation and corrosion, etc.
A "non charged" filter isn't charged. SCA's would be bad in a coolant that is already designed with them built in, like the Ford Gold or Cat EC-1 rated coolants that we should be using.
