Faulty switch?
Old Apr 1, 2011 | 10:07 PM
MiddleNameMUD's Avatar
MiddleNameMUD
Faulty switch?
This may be a dumb question however just want another opinion.
I am in the process of doing a 3g swap and temp. Wired it in, I went to start it and the starter kept cranking in the run position. It cranks untill I turn off the ignition, I think the problem is my ignition switch due to the fact that the soliniod stops when I key off. Could I have a wire wrong on my alty? Pretty simple install (3g) but it did not do this untill I swaped it.
Old Apr 1, 2011 | 10:45 PM
radar457's Avatar
radar457
check the 2 small wires on your solinoid. I think you have them reversed..
Old Apr 2, 2011 | 06:49 AM
MiddleNameMUD
I didn't touch those wires, they are still in the original location. I will try that and see if it helps, thanks radar.
50 something views and nobody else has an idea? strange...
Old Apr 2, 2011 | 09:22 AM
fmc400's Avatar
fmc400
MSEE
That's probably because radar chimed in with the most likely solution that anyone could give you at that point. You got solid advice within 40 minutes of asking a question on a Friday night; I'd say you did pretty good.
Since you didn't touch that area, can you describe the rest of the connections you made in your swap?
Old Apr 2, 2011 | 09:49 AM
MiddleNameMUD
Sure can fmc, I installed a brand new 3g with a factory mustang harness.
Power wire of the alt to 175 mega fuse to battery side of soliniod
yellow wire to pos
green/red excite wire to light or I terminal or so I think? Funny thing is is that there is no wire to the I on the v regulator, so after reading the 3g thread I gathered it was the same colour code is this where I am wrong??
Also the cab power wire, black/yellow stripe to pos battery post.
I believe that is it.
Btw I did thank radar for his sudgestion however without change to the three other posts on the soliniod I was hoping another sudgestion might have been given as well.
I realize I probably should've been a little more in depth with my op, I don't think I missed anything this time. Thanks for any help you can give!
Old Apr 2, 2011 | 09:56 AM
MiddleNameMUD
Sorry the cab power wire is on the mega fuse block after the fuse.
Scerb
Sep 1, 2016 06:10 PM
GM4WALLS
Nov 28, 2015 10:20 AM
sunbelt57
May 14, 2015 06:24 PM
abyars111
Oct 26, 2014 02:12 PM
surfmeister2000
4 Cylinder Engines
20
Nov 15, 2003 10:15 AM
