Rumble, Vibration at Part Throttle Under Load
Okay, it's been a while but I finally had a chance to start on this again. I hauled a car on a trailer a while back and it's definitely an engine problem. It becomes very clear under a load. I checked the TPS, EGR regulator, DPFE and all seem to check out. The EGR valve and ports are clear because the engine wants to die when you apply a little vacuum to the EGR valve at idle. I had suspected that the EGR wasn't opening when it should be and therefore a lean condition at cruising speeds. One question, though: I checked for vacuum to the EGR while in PARK inside my garage. I'll get up to 5-7" of vacuum, then an immediate drop with a slight drop in throttle position. Then I'll get about 3". I didn't think there should be any vacuum to the EGR while in PARK. Any thoughts? Thanks.
i have the same issue with my 2000 expo. no codes, changed the plus,ocv valvue, sea foamed it twice! changed fuel filter, replaced the bad CP, changed tranny fluid, that was not burnt, changed transfer case oil (was blk) change rear u joint... and i still get it on idle and then press the gas on a load...
battmanf16
1997-2006 Expedition & Navigator
22
03-11-2020 11:36 PM
Towmanjbo
07-17-2015 07:23 PM
honeydew
73
01-07-2014 05:51 PM
