2005 grill?
Old Apr 1, 2011 | 03:40 PM
jwill8957's Avatar
jwill8957
2005 grill?
Will a 2005 grill fit on my 2002 350. with some minor trimming maybe? pictures anyone?
Old Apr 1, 2011 | 08:40 PM
F350-6's Avatar
F350-6
Yes it will fit. Are you going with the 05 headlights too?
If you search long enough, there are threads here or up in the super duty section with photos showing how to do it. Basically you'll need to trim a little off the bottom of the grill. Put some tape on the grill and cut through the tape to keep it clean looking. Then you'll have to zip tie the bottom of the grill in place instead of using the little push lock fittings. The screw holes on top should line up the same. If you find an 05 bumper, then no trimming is required. It's all about the drop in the center of the bumper that makes us need to trim it a little.
Old Apr 1, 2011 | 09:52 PM
jwill8957's Avatar
jwill8957
Well I have strobes in my headlights for plowing so ill probably leave them go for now. I was just curious to see how it will look or if its even possible. Thanks!
Old Apr 2, 2011 | 06:32 AM
hammer65's Avatar
hammer65
Jwill8957:
Just do a search on 2005 grille on this site, and you will find several threads. Jim
Old Apr 2, 2011 | 08:36 AM
fordpower88's Avatar
fordpower88
Yes the grill will fit with some trimming on the bottom. The top four screws line up and I didnt use anything on the bottom to secure and it has been fine for almost two years now although some guys have secured the bottom with zipties or little screws. I don't have any pics of the trimming part but here is one of it finished.
Old Apr 2, 2011 | 08:38 AM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Here check this out.
https://www.ford-trucks.com/forums/7...a-99-04-a.html
Old Apr 2, 2011 | 08:41 PM
jwill8957's Avatar
jwill8957
looks good! im gonna have to do this
Bill Douthit
2004 - 2008 F150
Jul 11, 2014 02:00 PM
f350sdv10
Feb 4, 2010 04:49 PM
Sgan555
Appearance & Dress-Up
Aug 1, 2005 11:08 AM
h_bomb41
May 16, 2005 10:47 AM
superdutyaz
Jul 14, 2004 12:58 PM
