Power Steering Pump replacement
Old Apr 4, 2011 | 08:00 PM
TurboTuff's Avatar
TurboTuff
I eyeballed it when I pressed it on.
I believe your right.
Is there a way to test belt allignment?
Old Apr 4, 2011 | 09:54 PM
84-6.9L's Avatar
84-6.9L
Put the new belt on and eyeball it. The pulley hub should be flush with the end of the pump shaft. And make sure your not a rib off on any pulleys
Old Apr 28, 2011 | 08:06 PM
TurboTuff's Avatar
TurboTuff
I'm back!
Sorry about not posting but I've been without a pc for about 6 weeks!!
I repaired the tran coolant connectors and lines,put a new belt and realigned it.
Replaced the tran fluid I lost.
Everythings good.
Thanks again
Old Mar 13, 2013 | 10:08 AM
evoxone's Avatar
evoxone
Replacing Power steering pump with a powerstroke
Great thread, now I feel comfortable tackling this myself. I lost a power steering pump on my '94 E350 IDI and was able to pull one that looked identical off a 95 stroker, but now that I go to put it on I noticed the Powerstroke pump it has an additional inlet near the top. Anyone know what this is for? If it just goes to a resevoir for more fluid, could I just seal it up and use it?
Thanks,
Andi
Old Mar 13, 2013 | 11:40 AM
Phy's Avatar
Phy
An extra inlet as in a hose barb connection in the plastic reservoir just below the filler cap?
If so, that's for the return line from a hydroboost brake booster. You can just plug it and good to go.
nstueve
80
Feb 5, 2016 12:33 AM
tommyblack
2004 - 2008 F150
Jan 8, 2015 12:02 PM
SaturnSky11
1983 - 2012 Ranger & B-Series
May 29, 2014 07:32 PM
1saxman
2004 - 2008 F150
Aug 25, 2013 08:34 PM
