Sponsored by: Real Truck
Trans Cooler
Old Apr 1, 2011 | 09:34 AM
mstiles19's Avatar
mstiles19
Trans Cooler
So I really would like to put a better trans cooler on my truck, since i keep occasionally getting a trans fluid smell. I have read alot about people putting the 6.0 cooler on a 7.3 truck, but I have the 5.4gasser. Is there a trans cooler that I could put into my 2001 5.4?
Old Apr 1, 2011 | 10:38 AM
spinella's Avatar
spinella
the 6.0 cooler would work great on your truck.
Old Apr 1, 2011 | 11:22 AM
SuperDutyScaler's Avatar
SuperDutyScaler
i want the 6.0 cooler for my 5.4 for the past three years. problem is every time i get the money for it and find one cheap i spend the money on other stuff first.
Old Apr 1, 2011 | 05:05 PM
Bigpipes 35's Avatar
Bigpipes 35
My 03 has what seems a big factory cooler its about 25" long and 12" high I just installed a tranny temp guage so I can monitor the temp. Might be a good idea to get one before you get the cooler If its not getting hot maybe you dont need a different cooler.
Old Apr 1, 2011 | 07:18 PM
mstiles19's Avatar
mstiles19
ok thanks, I am pretty sure i need one, due to the trans fluid smell i get when i pull something large. Should it go in just like in a 7.3?
Old Apr 2, 2011 | 08:34 AM
Bigpipes 35
I think the 6.0 cooler is a direct bolt in you might have to change the fittings though.
Old Apr 2, 2011 | 09:40 AM
mstiles19's Avatar
mstiles19
Ok cool.
Are there any good sources for these around?
Old Apr 2, 2011 | 11:26 AM
jh818's Avatar
jh818
I believe you need to get a half inch diameter to a 3/8" diameter barbed hose fitting. The outlets on the 6.0 cooler is half inch while the lines from your tranny is 3/8" dia. Everything else should bolt directly on. You'll need 2 of those fittings and 4 of those screw type clamps to secure the hose on the fittings.
I think I saw those fittings at Lowe's where they keep those little brass pipe fittings and elbows, etc.
Good luck. If you can, please post pictures of your install. I would like to do this mod someday when I have more $$$.
Old Apr 2, 2011 | 12:49 PM
Firefighter 1406's Avatar
Firefighter 1406
I was having a problem with my tranny getting hot this winter while plowing. I looked at the 6.0 cooler also but couldn't find a good deal on one. I went to my local orielly auto parts and bought the ten inch electric fan they have in stock, $59 bucks. Added it on top of the tranny cooler. Now when it starts to get warm just flip a switch and watch the tranny temp gauge go down. Not discouraging the 6.0 cooler just giving you a different options.
