Cab/Bed Alignment
Old Mar 31, 2011 | 08:19 PM
TX92F150's Avatar
TX92F150
Cab/Bed Alignment
I have a 1992 F-150 Super Cab. The body lines on the cab don't align with those on the bed. It's a lot worse on the LH side than the RH side. The truck has all-original paint, has never been hit, and has never been apart. From observing other trucks of the same era, it seems to be a fairly common trait.
Is the fix to replace the cab mount "biscuts"? Mine are showing their age, but don't want to dig into that if it's not the problem. I can't really think of anything else it might be, except that they were just built that way. I can't think Ford would let them out with that much mis-alignment though.
If everyone agrees that it is the rubber biscuts, where can I find replacements? Is it a stealership-only item, or is there another source?
All input is appreciated.
Thanks,
JD
Old Mar 31, 2011 | 08:42 PM
CWPottenger's Avatar
CWPottenger
LMC Truck Parts - Page 22
76250_4x4's Avatar
76250_4x4
if you want the stock rubber ones then the dealer is your best bet, otherwise there are a few aftermarket companys that make polyurethane ones. the poly ones come in a set for your whole cab and i think they are around 60 bucks. personaly id go with the polys
Old Mar 31, 2011 | 09:20 PM
zxwut?'s Avatar
zxwut?
I'd go with the rubber unless you like squeeks.
Old Mar 31, 2011 | 10:51 PM
76250_4x4's Avatar
76250_4x4
ive never had a single squeak from a poly bushing
Old Mar 31, 2011 | 10:56 PM
KevinGnWV's Avatar
KevinGnWV
The village idiot.
I had a chebby truck squeak. I took them back apart and coated both sides and the bolt hole with vaseline and that fixed it.
Old Mar 31, 2011 | 11:10 PM
TX92F150's Avatar
TX92F150
So, the consensus is cab mount bushings. I'm leaning towards OEM to maintain the factory set-up. I think the poly mounts might transmit too much NVH into the cab. Anyone using the poly mounts notice this?
JD
Old Mar 31, 2011 | 11:23 PM
zxwut?'s Avatar
zxwut?
I noticed that they get squeeky after a while and you have to lube them up again which requires unbolting and lifting it all again, whereas the rubber does not.
Old Mar 31, 2011 | 11:28 PM
KevinGnWV's Avatar
KevinGnWV
The village idiot.
Your probably right, it would have to be re-done and replace the bolts every so often as well. Truck burnt to the ground a few months after I swapped bodies. (Thank you quadrajet )
I did notice on my F150 the front squeaked a lot after installing poly sway bar bushings. I'm not positive it was them squeaking since I heard it in the cab, but I never heard the squeak before I put them in.
AXracer
26
Jul 29, 2023 10:54 PM
sandymane
37
Jun 6, 2017 09:03 AM
Tylus
Aug 15, 2016 10:21 AM
biscut
Aug 31, 2015 03:51 PM
Filko
18
Jan 15, 2015 01:46 AM
