Flat head temp switch/sender combo question
Old Mar 31, 2011 | 06:39 PM
jb50F1's Avatar
jb50F1
The wiring for the temperature switch/sensor combination appears to be wrong. The temperature switch on the passenger side appears to be bypassed (both leads connected to the out side so acting as a connection only rather than a switch) and the temperature sender switch on the drivers side is connected in line. The gauge sits at hot with the ignition off and appears to be accurate (?) when the motor warms up. There is no continuity across the switch so it is probably no good. Is there a problem using only the sensor on one side and not using the switch on the other? Thanks in advance for any help.
Old Mar 31, 2011 | 06:48 PM
Doc's Avatar
Doc
That's the way it works. The right side temperature sender is connected to the left side sender which communicates directly with the temp gauge in the cab. When the ignition is off, the gauge falls to hot (different than modern vehicles which usually fall to cold). Then when you turn the key on, it goes back to the measured temp on the gauge.
Old Mar 31, 2011 | 07:10 PM
jb50F1's Avatar
jb50F1
It appears to be using the sensor only - not the switch based on the wiring. A replacement switch seems expensive ($90 or so) and if it is OK to leave as is, that would be great. The switch unit is bad based on a continuity test and the sensor unit is working fine.
Just looking for advice on whether or not checking the heat from one side only without the boil over switch on the other side is a problem or if it is a good idea to replace the switch. How often have flat heads had problems with one side with overheating but not the other? Separate water pumps etc. makes me wonder if it is a good idea to be monitoring one side only.
Old Mar 31, 2011 | 08:36 PM
Doc's Avatar
Doc
Well theoretically the water communicates to both sides considering it gets mixed in the radiator. But I see your point. I have a question--are you saying that the switch with the 2 leads is on the passenger side (even though the PO put both wires on one side) and the functioning sender with one pole is on the driver's side? IF so, isn't that backwards guys?
Old Mar 31, 2011 | 08:57 PM
jb50F1's Avatar
jb50F1
Yes, the drivers side has the sensor with one wire. That is going back through the switch on the passenger side. The switch on the passenger side then goes back to the gauge (unless it is bypassed as is the case here so that the sensor goes directly back to the gauge). If I understand the way the system is supposed to work, the switch (in my case on the passenger side) is always closed allowing the current from the sensor (in my case on the drivers side) to pass back to the gauge unless the temp on the passenger side goes above XX degrees (somewhere between 206 and 212) when it opens and sends a signal to the gauge to go to full hot. It shouldn't matter which side is which as long as the sensor comes first and the switch follows between it and the gauge when run in series? I just want to know if it is reasonably safe to have only one side the the engine monitored.
Old Mar 31, 2011 | 09:09 PM
Doc's Avatar
Doc
I understand it like you do. And I agree it shouldn't matter which side theoretically. As I understand it, the switch is an "all or nothing" type anyway. So I don't think you're gonna get more information from that side of the engine anyway other than it's either 206ish or not. BUT, I just worry that the electrical system/gauge could be damaged by the continued flow of current after the truck heats up without the benefit of the "kick out" by the switch side. I was hoping somebody with more expertise would jump on this and straighten us out.
Old Mar 31, 2011 | 10:33 PM
larryb346's Avatar
larryb346
If you had a water pump impeller failure on the unmonitored side you could easily over heat and ruin your engine. Same with head gasket issue. I would recommend, at the least, you install a mechanical guage to monitor that side. Then you would be able to keep track of both sides. I wouldn't want to drive it as you discribe with the one side with no temp. check ability, but that's just me.
Larry
Old Apr 1, 2011 | 06:29 AM
r_reed's Avatar
r_reed
since a lot of fte's convert to mech gauges, maybe there is someone around who would part with a the switch sensor. you could put a want ad in. should be easy enough to test a used one with continuity tester and hot water.
Old Apr 1, 2011 | 07:09 AM
petey shoes's Avatar
petey shoes
i feel the same as larry on this. two different banks that act like two 4 cyl engines, as far as cooling system goes. i put an electric send unit with independent gauges for each side. i was surprised to find that they do not run as consistent as you might think. (especially when idling). this set-up will show any symptoms/problems before they escalate to larger issues.
Old Apr 1, 2011 | 07:27 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Larry
Not just an impeller failure, but if the thermostat were to stick on one side, you would never know until there could be significant damage to the engine. Especially, if you run aluminum heads.
I have my instrument cluster apart, cleaning and painting the needles, and I've considered replacing the oil gauge with a second temp gauge. Right and left. I would install a mechanical oil gauge in the steering column drop. It wouldn't be necessary, but I think it would look cool to be different, but the temp gauges would look totally original.
Old Apr 1, 2011 | 07:30 AM
jb50F1's Avatar
jb50F1
Thanks all - that is what I suspected when I found the problem. I will replace the switch ASAP and really consider a more accurate way to follow the temp on both sides.
Old Apr 1, 2011 | 02:55 PM
snipa's Avatar
snipa
I did the same thing on mine. 2 gauges under the dash near the defrost
I fell a lot better knowing the accurate temp of each side
Old Apr 1, 2011 | 03:53 PM
bobj49f2's Avatar
bobj49f2
I chased what I thought was an overheating problem for weeks until I pulled the sensors and installed two mechanical gauge units, my engine doesn't go over 180° at all.
Old Apr 1, 2011 | 04:37 PM
4tl8ford's Avatar
4tl8ford
The right side sensor is a on/off switch - If the right side goes past a set temp the switch opens and sends the Gage to HOT.
The Left side switch is a temp sensor which indicates PRIMARILY (considering radiator mixing) the temp of the water in the left side.
If you want to monitor both side temps you need two left side sensors and two gages each with its own wiring.
NOTE two left side sensors can use one Gage if you use a three way switch - On-Off-On - I don't trust the operator (Me) to switch sensors often enough.
Old Apr 1, 2011 | 05:07 PM
ALBUQ F-1's Avatar
ALBUQ F-1
By the time the Switch clicks open, you're toast anyway. As usual, it helps to remember that these trucks worked just fine this way for the last 50-60 years... relax and enjoy the ride!
