Patch Panel Advice..
Old Mar 30, 2011 | 04:30 PM
v8xploder's Avatar
v8xploder
Im working on doing a patch panel. I have welded my patch panel in already and even though I took my time and welded in different spots all over the panel to prevent warping I still had some low areas where I welded. Anyway I didnt think it was a big deal but I used my stud welder gun to well pull out my low spots because on once section of the patch panel I cannot really get to the back side. Well the metal must have gotten too thin after my rough grinding and my stud burnt a hole right thru the panel.
And again I thought no big deal. I got the welder out and was going to do a small fill and it instantly burned a bigger hole. What Im trying to say is I have some thin metal and I cant use my welder to fill any holes. I could try to stick a piece of sheet metal behind it but I dont know If i can get behind one section. Im pretty new to body work so this is where I need you kind fellows to toss me a rope. Im thinking maybe my only option is maybe some lead or maybe even JB weld? I want some solid metal (material) behind my filler and paint! Thanks guys.
Old Mar 30, 2011 | 07:06 PM
Action4478's Avatar
Action4478
If you are not using too large of a welder , you should be able to slowly build of weld around the newly formed hole . Weld it a touch at a time & let it cool completely in between welds ..
BTW , what are you using to weld ?...
Old Mar 30, 2011 | 08:15 PM
v8xploder's Avatar
v8xploder
Its an eastwood 110v mig, Argon & co2
Old Mar 30, 2011 | 09:35 PM
Action4478's Avatar
Action4478
Should have been fine . Make the hole as big as needed till you get to solid metal to to fill it with weld ...
Old Mar 31, 2011 | 04:31 AM
v8xploder's Avatar
v8xploder
Thanks, I'm going to go at her again tonight and see what happens. When you fill a small hole generally do you turn the voltage and wire speed down? Or make shorter trigger pulls/duration with the same setting you use to weld?
Old Mar 31, 2011 | 07:36 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
For the places you can get behind, back it up with a piece of copper, weld won't stick to it and acts as a heat sink.
Old Mar 31, 2011 | 08:01 AM
v8xploder's Avatar
v8xploder
I just ordered a kit from eastwood. Nice copper spoon set with handle that I think will be perfect. Thanks
Old Mar 31, 2011 | 08:16 AM
Action4478's Avatar
Action4478
I have 4 settings an my miller , I use the highest most of the time .. If I were filling a hole I would turn it down to 3 without changing the wire speed ,until I have weld completely around the hole by using a stitch weld (short trigger pulls ) letting it cool after each . You can then turn it back up & weld the hole shut , still using caution ...If the weld builds to high , grind it down before proceeding ...
Old Mar 31, 2011 | 08:17 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
That'll work. I use flattened copper fittings/pipe from Lowes and a set of vise grips. You can bend to fit and adjust handle to where you want it.
Old Apr 1, 2011 | 10:18 PM
PatsPOS's Avatar
PatsPOS
I'm no welder by any stretch, so take what I say lightly. What gauge wire are you using in your welder? I started off welding patch panels with .030" wire, and I could burn a hole in just about anything, and warp panels further than NBC warps the truth. I switched to .023 wire, and I was putting in patches like a pro.
Pat
turnrjr
18
May 19, 2012 08:16 AM
ProStreetDriver
Paint & Bodywork
Feb 4, 2012 01:23 PM
v8xploder
Paint & Bodywork
Jan 2, 2012 09:57 AM
koolhandluke
Feb 21, 2011 04:56 PM
bulletsneverlie
Paint & Bodywork
Apr 12, 2009 09:13 AM
