Bad GEM or Bad Ignition Switch?
Old 03-10-2011, 07:33 PM
gto*dan's Avatar
gto*dan
gto*dan is offline
'97 F150 Scab 4.6 auto 2WD
Check me out on this: factory radio plays & key-in chime sounds with ignition switch off & key removed. This results in dead battery in a few days time. I’ve had it in, previous to the phantom radio/door chime occurrence, to the only pro mechanic that I trust and he pulled down the GEM and it was uncorroded and dry. He said that it looked good to him since he has seen bad ones before.
Question: shouldn’t I throw $20 Ignition switch at it (versus $200+ GEM cost) to cure this 2 yr dead battery PITA?
Thanks for your help.
Old 03-11-2011, 06:02 AM
Joe Finn's Avatar
Joe Finn
Joe Finn is offline
I'd say it's a no-brainer to try the switch first unless you have some better evidence that the GEM is at fault.
Old 03-14-2011, 05:27 PM
gto*dan's Avatar
gto*dan
gto*dan is offline
Now There's No Power to Starter
First of all - Joe thanks for your reply. Do you know if the start circuit goes through the GEM? I haven't replaced the switch yet - so I'm still wondering if it is the real culprit and not the GEM. Its just I see so many posts about bad GEM problems and none about a bad switch. Maybe this problem of no power to starter circuit would isolate it to one or the other.
What do you think?
Old 03-14-2011, 07:01 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
The starter circuit does not go through the GEM.
I'd suspect the I/P fuse box. The switch is easy to test...
Old 03-30-2011, 09:30 PM
gto*dan's Avatar
gto*dan
gto*dan is offline
Resolved
Turns out there was 2 problems: no power to starter was bad firewall solenoid & spooky radio/key-in chime was a bad GEM. Solenoid would only click and failed during the GEM - I/P fuse block trouble shoot. Replaced GEM with one from '98 and no problems with it this last week.
Thanks for the help.
dlynes
10-23-2017 04:38 PM
FuzzFace2
02-26-2016 03:19 PM
Craig46
1947 and Older Ford Trucks
35
12-19-2015 02:16 PM
trippn4re
23
06-02-2014 04:16 PM
lakerats
Electrical Systems/Wiring
12-08-2010 08:00 AM
Quick Reply: Bad GEM or Bad Ignition Switch?
