Jump started/Starded/Died/Will not start
Old Mar 30, 2011 | 10:50 AM
283lan's Avatar
283lan
Hello all, my brother inlaw has a 6.0L in a 05' 350, I don't know the whole story but this is what i know. They had to jump start for what ever reason, hook the jumper cables up, started the truck and had it running for about 30 seconds, when they pulled the jumper cable off she died and now will not start. There is fuel at the rail, oil preasure when cranking, checked all the fueses he could find and everthing seems to be fine (can hear fuel pump cut in, glow plugs come on/off, check engine light NOT on, no codes on a OBD reader) but crankes and wouln't fire.
Any other suggestions ?
Thanks for the help.
Old Mar 30, 2011 | 11:21 AM
2006powerstroke90's Avatar
2006powerstroke90
Batt's might still be weak since you had to jump start it...Charge the batt's up for a decent amount of time, and see what happens...
How long was it sitting?
Old Mar 30, 2011 | 11:29 AM
fast_st's Avatar
fast_st
could be a flat dead alternator. Other than that not sure, check for codes, check fuses?
Old Mar 30, 2011 | 12:09 PM
Unrealo4's Avatar
Unrealo4
Alternator, also the batterys may be toast. Charge em and load test them.
benfishn
Aug 23, 2024 06:31 AM
arkredneck
24
Jan 12, 2015 11:33 PM
biggamehunter222
Jan 15, 2014 06:34 PM
msfprobass
1978 - 1996 Big Bronco
Jul 30, 2012 02:18 AM
saltydog73
Dec 31, 2006 12:42 PM
