At Wit's END - need help please.
Old Jun 1, 2011 | 08:38 PM
CosmoStarr's Avatar
CosmoStarr
Arrow UPDATE - Finally have the Codes
Okay finally had the codes read this afternoon.
Code 1: P0472
Exhaust Pressure Sensor and it read low
Code 2: P1271
Injector wiring - injector 1
So what do I need to do to correct the problems?
Is the Exhaust Pressure Sensor the same as the EBPV?
https://www.ford-trucks.com/forums/1...ave-codes.html
Old Jun 1, 2011 | 09:13 PM
HD Rider's Avatar
HD Rider
There is a tube from the front of the pass side exhaust manifold leading to the exhaust pressure sensor located under the pastic engine cover. The tube and sensor may need to be cleaned.
The EBPV is located back in the turbo pedistal. These will not cause your no start issue.
The injector wireing is where I would look.
Old Jun 2, 2011 | 12:25 AM
CosmoStarr's Avatar
CosmoStarr
can the wiring be fixed? Or does it need a new UVCG?
Old Jun 2, 2011 | 12:56 AM
Muktown's Avatar
Muktown
Check the one going into the valve covers there is a connector there that sometimes likes to vibrate loose otherwise you will need to pull the valve covers to check them out. They may be melted or simply just making a poor connection.
Old Jun 2, 2011 | 09:50 AM
CosmoStarr's Avatar
CosmoStarr
Question
Thank you -
Are the ODD # injectors on the passenger side or the driver side?
Old Jun 2, 2011 | 02:19 PM
PastorPaul's Avatar
PastorPaul
Originally Posted by CosmoStarr
Thank you -
7.3 IDI Diesel, 1-2-7-3-4-5-6-8
7.3 Litre DI Powerstroke Diesel, - 1-2-7-3-4-5-6-8
7.3 PowerStroke Engine Specifications
Type: Diesel, 4-Cycle Type, Direct Injection
Configuration: OHV V-8
Displacement: 444 cu. in. (7.3 litres)
Bore & Stroke:4.11 x 4.18 in. (10.44 x 10.62 cm)
Compression Ratio: 17.5:1
Aspiration: Turbocharged with Back Pressure Device for warm-up
Rated Power: 210 hp @ 3000 rpm
Rated Torque: 425 lb.-ft. @ 2000 rpm
Total Weight - Dry: 920 lbs (417 kg)
COOLING SYSTEM
Water Flow: 80 gpm @ 3300 rpm
Thermostat Location: In Water Pump Housing
Water Pump: Centrifugal Type
Water Pump Rotations: Clockwise
Fan Hub: Right-Hand Thread
Lubrication System
Type: Full Flow
Capacity (Including Filter): 12 U.S. Qts. (11 liters)
Oil Pump: Gearotor Pump
Oil Cooler: 30 Fins per inch
Lube Oil System: Enhanced for New Injection System
Lube Oil Filter: Microglass - Extender
Oil Filter Motorcraft/Part Number: FL-1995/F4TZ-6731-A
Oil Drain Interval: 3000 - 5000 miles with microglass filter
High Pressure Lubrication System
High Pressure Pump: Gear Driven Swash Plate
Pressure Control: Pulse-Width Modulated Pressure Regulated Spill Valve (EEC-V)
Oil Rails: High Pressure Rails in Cylinder Heads
Oil Lines: High Pressure from Pump to Rails
Lubrication Oil Tempurature: Used for Injection Control Strategy
Fuel System
Type: Electronically-controlled Direct Injection
Supply System:
Pump: Mechanical Tandem: Diaphragm/Piston
Filter: Replaceable Element (FD-4595A/F4TZ-9N184-B)
Return: Flow Regulated
Fuel Delivery And Control:
System: Unitized Injectors
Injector Actuation: Hydraulic/Electrical
Injector Timing: Electronic Controlled by EEC-V (not adjustable)
Fuel Control: Electronic
Diagnosis: EEC Quick Test, Diagnosis with Super Star Tester II, Pressure Gauges
Electronic Engine Controls
System: EEC-V
Injection Control: Injector Driver Module
Cylinder Head
Combustion Chamber Design: Re-entrant Chamber in Piston
Rocker Arm Assembly: Plate-Type Valve Lever
Exhaust Valve Material: Made of Hot Forged 21-2n Material
Fuel Passages: In Cylinder Heads
Cylinder Block
Cylinder Block Material: Cast Iron
Piston Material: Aluminum-Alloy, Cast in Ni-Resist Insert
Integral Combustion
Piston Rings:#1 Full Keystone, #2 Taper Faced, #3 Two Piece Oil
Connecting Rod Design: Forged Steel, Larger Connecting Rod Bore for Wrist Pin, Larger Boring Surface
Piston Pin Bore Diameter: 1.3086 in. (21.45 cm)
Ford Most V8 Engines
Old Jun 2, 2011 | 03:12 PM
PastorPaul's Avatar
PastorPaul
I tried to post a picture but it won't let me.
Passenger side front to rear 1234
drivers side front to rear 5678
Hope this helps
Old Jun 2, 2011 | 07:24 PM
F350-6's Avatar
F350-6
Passenger side odd, driver side even (at least in the US. some of our over seas members have the steering wheel on the wrong side )
Old Jun 2, 2011 | 08:13 PM
SkySkiJason's Avatar
SkySkiJason
After being plugged in does it start and run normal?
I dont think those codes directly equal a no-start....
Old Jun 3, 2011 | 09:44 AM
CosmoStarr's Avatar
CosmoStarr
Thank you Paul and Chris for the great information.
It starts - sounds like a thrashing machine but have figures out how not not have the Roaring Romps... The truck actually drives like it is starved for fuel. It is drivable but not normal.
So I am thinking that I need to replace the UVCH?
Old Jun 3, 2011 | 10:52 AM
SkySkiJason
At least look at the UVCH's and make sure they are plugged in all the way.
Old Jun 9, 2011 | 08:33 PM
Ron Severs's Avatar
Ron Severs
2000 7.3 F350 six speed straight drive
Need some advice on where to start:Was towing my 36' cargo trailor and the truck started loosing power and running rough. Had it programed with the Super chip light tow. Stopped and changed it to stock and went on for about 30 miles and same thing happened. Stopped and changed the fuel filter and the fuel pump inside the frame rail. No change. Before this problem I had just installed the 4" exhaust system. Any help?
Old Jun 9, 2011 | 08:37 PM
  #28
BigAlsPSD's Avatar
BigAlsPSD
Welcome, you should start a new thread for a few more hits but, here's info on the UVCH harness, https://www.ford-trucks.com/forums/8...t=truck+shakes
Sounds more like it might be an issue with clogged screens in the mixing chamber, Welcome to guzzle's In-tank Hutch Mod Web Page
Do you get a Service engine soon (SES) light?
Old Jun 9, 2011 | 08:51 PM
  #29
Ron Severs's Avatar
Ron Severs
No, no service engine light or codes.
Old Jun 9, 2011 | 08:54 PM
  #30
BigAlsPSD's Avatar
BigAlsPSD
Sounds more like the clogged mixing chamber screens then.
