I recently changed my EBPS and the tube. Both were very clogged. The problem is that most of the threads on the nipple coming off of the block came off of the nipple and remained in the tube collar. The same thing happened with the threads where the EBPS screws in. I have been trying to find the part numbers for the nipple at the block and the part where the sensor screws in but I have had no luck in doing so. Any help would be appreciated.
all ready replace those 2 items, the 2 things i need are the actual nipple that is screwed into the engine block and the bracket that the sensor screws into
I dont have one in front of me to look at but trying to find pics, seems like it does thread into the manifold, if thats the case I have a spare pass manifold that I could look at to see if it's removeable, if so I could send it to you.
