HELP PLEASE I MESSED UP
Old Mar 28, 2011 | 04:23 PM
grizzly11's Avatar
grizzly11
I took out th pcm to get the code for a chip and first found that there has been a chip in the truck not to happy about that previous owner said there has never been. It wont go back in i inserted it the the side that says this side up and nothing lines up. what am i doing wrong
Old Mar 28, 2011 | 04:30 PM
big poppa's Avatar
big poppa
Its been awhile for me but are all the pins look straight?? Did you pull it out straight??
Old Mar 28, 2011 | 04:47 PM
grizzly11's Avatar
grizzly11
no pins are bent all straight. I wasnt paying attention when i took it out thats my fault. I used the "this side up" when putting in back in b/c i thought that the pcm needed to be a certain way. Could it be that the "this side up" was for when putting the cases back togather?
Old Mar 28, 2011 | 04:54 PM
empiretc's Avatar
empiretc
the plug is slotted, so it is only going to go in one way.
you may just need to line everything up and get the bolt start. make sure it turns easily, and it should come together.
Old Mar 28, 2011 | 05:01 PM
frdf250's Avatar
frdf250
are you talking about the PCM itself? if so just try flipping the actual PCM around, i know my plastic shroud sayd this side up...but that is the plastic shroud. ive done this before and just flipping it makes it go in right. dont try and force it. it should go in smooth
Old Mar 28, 2011 | 05:12 PM
grizzly11's Avatar
grizzly11
yes there is only one way that the shroud can go after i fliped it it slid right into place but im am worried that its not right if i plug it in it will just fry the pcm correct then a big bill and i dont need that
Old Mar 28, 2011 | 05:21 PM
grizzly11's Avatar
grizzly11
i just watched powerstrokehelp's video on a dp f5 install on youtube and when reinstalling he said that the "X" on the cover faces the fender well? can some one verify that
Old Mar 28, 2011 | 05:56 PM
grizzly11's Avatar
grizzly11
i got it up and going thanks for the help i did notic that it starts better. Could the pcm being unpluged re set it?
Old Mar 28, 2011 | 07:17 PM
big poppa's Avatar
big poppa
I believe unhooking the batteries for a ammount of time your computer relearns your specific driving habits, highway, local cruising and so on, I guess unpluging the PCM you'll get the same if not better results. Just what I've learned over the years with computer controled vehicles, glad you got the PCM back in.
zx250's Avatar
zx250
Of the next Riffraff East
Originally Posted by grizzly11
.... Could the pcm being unpluged re set it?
Yes it would and did.
Old Mar 28, 2011 | 07:51 PM
JOHN2001's Avatar
JOHN2001
Verified, Thats how it should go back in
Old Mar 28, 2011 | 08:07 PM
grizzly11's Avatar
grizzly11
Thanks guys you are a great asset to everyone
