Not on the grill that I have seen, but the ford emblem and bed light yes. The front bumper has rust and the tailgate cable supports one is significantly longer than the other.
Have my laundry list for the dealer to fix. I have not taken in in since I took delivery in Sept 09.
The chrome is bubbling up on the grille my 2007 F350. I had to park outside quite a bit last winter and when I plugged it in the snow melted off the hood and went down onto the grille and froze. I think this freeze/thaw warped the plastic grille and caused the chrome to pucker and bubble.
Tires are junk as well, as far as wear goes.
you can easily adjust the tailgate cable by using a torx bit to loosen the attaching bolt and moving it forward on the "longer one".
