Sponsored by: Real Truck
Ranch Hand bumper ?
Old Mar 28, 2011 | 10:04 AM
cajun81's Avatar
cajun81
Ranch Hand bumper ?
Ok so here is one for all the guys with “ranch Hand” style bumpers. I just picked one up and I am wondering is it safe to drill and tap a fitting into it and fill it with air. And if so what would be a safe amount 60-80psi. It would be nice to have something to break lugs on the side of the road or fill a tire. If anyone has done it and have pics or suggestions let me know.
Shelton
Old Mar 28, 2011 | 10:16 AM
maverick22's Avatar
maverick22
Originally Posted by cajun81
Ok so here is one for all the guys with “ranch Hand” style bumpers. I just picked one up and I am wondering is it safe to drill and tap a fitting into it and fill it with air. And if so what would be a saf amount 60-80psi. It would be nice to have something to break lugs on the side of the road or fill a tire. If anyone has done it and have pics or suggestions let me know.
Shelton
Good idea, I hadn't ever thought of that. I would have 2 concerns though - I'm not sure the welds on the pipe are air tight, so it may not even hold air, but secondly it's not stainless steel so I would be concerned about rust on the inside of the pipe. That said, give it a try, worst comes to worst you can weld it back shut.
Old Mar 28, 2011 | 11:17 AM
hanklin's Avatar
hanklin
Why not check out Viair compressors, VIAIR Corporation - 12 & 24 Volt Air Compressors
Pretty handy all around.
Old Mar 28, 2011 | 11:48 AM
cajun81's Avatar
cajun81
thats a nice kit but i am not looking to spend any more money. i am looking to set somthing up for emergency use and maby a little odd and end stuff.
Old Mar 28, 2011 | 02:06 PM
sledheadm7's Avatar
sledheadm7
i dont think they seal them up all the way they leave weep holes in them so water dosnt stay inside the bumber and rust out but u could always just weld shut idk not sure i would want compressed air in a bumper u get in to a small fender bender and the bumper may explode just saying.
Old Mar 28, 2011 | 02:11 PM
wizardsr's Avatar
wizardsr
I don't know about exploding, but I can't see a tube bumper having enough capacity (air volume) to be worthwhile for this purpose.
Old Mar 28, 2011 | 02:39 PM
cajun81's Avatar
cajun81
good point,but just enugh to break lugs with an Impact wrench in the rain on the side of the road might be worth a shot
Old Mar 28, 2011 | 04:04 PM
hanklin's Avatar
hanklin
What you do is drive to Mexico and stuff that sucker full of drugs, drive back and bingo !!! look at all that money you have just kidding
Is there enough pressure that you can store in there to work a impact wrench? I would think that if it was plausible then peeps would have made it known a long time ago. Good luck and post up results.
Old Mar 28, 2011 | 04:17 PM
cajun81's Avatar
cajun81
[quote=hanklin;10150723]What you do is drive to Mexico and stuff that sucker full of drugs, drive back and bingo !!! look at all that money you have just kidding
quote]
the problem is welding it back together without "damaging the goods"
somebody has to have done this before, there is no way that i am the first to think of it. i am just not that smart
Old Mar 28, 2011 | 04:21 PM
Byram's Avatar
Byram
On the amount of air - I figured that a 5" pipe - about 7' would hold 6-8 gallons... Now - the Ranch hands are 4" - at least mine is... I am going to do the same thing - but on my own pipe bumper - not my ranch hand - mainly because of the volume, welding it up "right" because I am not sure of their integrity, and actually I like my own design better.. Just ran out of time & so I have to put a ranch hand on for a while.
On another note someone hit the right side tubes around the headlight on mine & it bent (very little ) but on my homemade bumpers - all my framing stock - except for the main pipe is 1/2" x 1 1/2" bar stock turned edgewise & it very strong...
Old Mar 28, 2011 | 04:23 PM
hanklin's Avatar
hanklin
cajun 81,, reps sent for luck
Old Mar 28, 2011 | 04:24 PM
hanklin's Avatar
hanklin
[QUOTE=cajun81;10150770]
quote]
Jb Weld??????
Old Mar 28, 2011 | 04:36 PM
maverick22's Avatar
maverick22
I think they're a 4" sch. 40, so assuming an ID of 4.026" I come up w/ 3.96gal capacity using a 6' pipe length so if the total length is 7' that would increase it slightly. So in theory it would hold as much as a smaller household air compressor - enough to air up a tire but maybe not enough to break 8 lugs loose.
Old Mar 28, 2011 | 04:52 PM
cajun81's Avatar
cajun81
what if i tap this into one side and have a QD on the other
Firestone Air Compressor, Firestone Compressors, Firestone Air Bag Compressor
Old Mar 28, 2011 | 05:03 PM
BigPigDaddy's Avatar
BigPigDaddy
