Sponsored by: Real Truck
Ranch Hand bumper ?
Old Mar 28, 2011 | 05:17 PM
hanklin's Avatar
hanklin
Originally Posted by BigPigDaddy
then we all get together and I`ll bring the buns and everyone else bring dogs,beer marshmallows etc
Old Mar 28, 2011 | 08:59 PM
F350-6's Avatar
F350-6
I've seen it done. I don't know about running an impact off it, but they were used to top off low truck tires or air up little tires. In addition to the air hose fitting, you'll also want to put in a schrader valve so you can air it up. A gauge and possibly a water drain might be useful too. The ones I've seen done held 150 psi fine. I don't know if they had to weld up any leaks before using it that way.
Old Mar 29, 2011 | 12:46 AM
BigPigDaddy's Avatar
BigPigDaddy
Yes, it would definitely be handy for airing up a low tire to get you where you need to go.
Old Mar 30, 2011 | 01:14 AM
JKBrad's Avatar
JKBrad
I used to work for Ranch Hand. This was back in the mid 90's though. We used sch 40 pipe, welded to a 1/2" drop plate. The end caps were 12 ga diamond plate. The welds were certified through a 3rd party testing company for rated weight strength, but not for porosity. Even if the welds were perfect, the end caps wouldn't support much PSI. There were some small companies building air tank bumpers with sch 40 caps on each end, but the demand was small and the price was high. I wouldn't try to convert a RH or any similar bumper to an air tank. You may be able to find a local pipe fitting or oilfield service welder to build you one based on a RH design.
Old Mar 30, 2011 | 03:18 AM
78bigbronco's Avatar
78bigbronco
Originally Posted by hanklin
I would think that if it was plausible then peeps would have made it known a long time ago. Good luck and post up results.
Originally Posted by cajun81
[somebody has to have done this before, there is no way that i am the first to think of it. i am just not that smart
It has been done before I know folks here have even done it. Must be none of there are around right now. Even seen it on 4 wheeler magazine. Not sure what bumpers, probably not ranch hand, maybe all diy, idk. Would be even better with a twin tube bumper
One idea I am toying with is making ss cab steps that are actually small air tanks for an onboard air setup.
Old Mar 30, 2011 | 07:19 AM
Lubbockguy1979's Avatar
Lubbockguy1979
The capacity would be the issue. If it were me and the impact was the goal. Get a nitrogen tank or a co2 tank and regulator. It will be cheaper than a compressor set up and is very common in the 4wheel world for the exact purpose your wanting. I just don't see 150psi of air lasting long with such a small capacity. Another option would be a 18-36v cordless impact. I actually bought a dewalt kit with the big impact (18v) haven't had a opertunity to play with it on lugnuts but it will be awesome if it works good.
Old Mar 30, 2011 | 08:44 AM
cajun81's Avatar
cajun81
the sides are 12 ga dimond plate on the one that i have i was looking at it yesterday. it seams like that is the weak link.these are all good points to consider, thanks guys. i really want onboard air but i dont want to spend any more money on the truck at the moment and i thaught this was a sure fire way to do it for cheap
Old Mar 30, 2011 | 09:41 AM
maverick22's Avatar
maverick22
Didn't realize the end caps were that thin, good point! But still, about an hours worth of time, a torch, some 1/4" plate, a welder and some krylon and you're back in business. A pain yes, but depends on how much you want it.
Old Mar 30, 2011 | 12:43 PM
sledheadm7's Avatar
sledheadm7
or you could carry this 5 gallon tank. only 40 bucks
5 GAL PORTABLE COMPRESSED AIR PRESSURE STORAGE TANK on eBay!
or even better one of these
Original HyperFlo SOURCE CO2 Air Systems
Old Apr 3, 2011 | 10:31 AM
cajun81's Avatar
cajun81
thanks for the input i installed the bumper yesterday and i will save some money and install a onboard air system later.
original 99-04 crome dent and scratch free bumper for sale in marketplace.
Old Apr 3, 2011 | 11:28 AM
flamebuster's Avatar
flamebuster
I built a pipe bumper for my winch on my old '88 F-250. and used the pipe as an air tank.
When I baught my 2004 F-350 King Ranch I didn't want to ruin the looks of the front end.( I like the stock bumper) so I built a push bar for the the winch. And took a air tank off one of our old semi trucks. I think it is 10 or 12" dia. and close to 2' long. I mounted it outside the frame between it and the sheet metal side of the box, at the front of the box on the drivers side. It is completely out of sight. I have a viarr in the cross box tool box and I installed a regulator in the tool box off a tee fitting, the 3rd part of the tee goes out the box to qd. for the air hose. The regulator is set up to automatically run the compressor and set at 175 psi. max. enough for the air impact or airing up tires....and of course the train horns
You can find these tanks at any trucking co. or salvage yard for next to nothing...Just anouther option to consider.. Ohh and I do have a switch in the cab to shut off power to compressor when not needed..
ten.mile
May 16, 2020 04:34 PM
Craig46
1947 and Older Ford Trucks
35
Dec 19, 2015 02:16 PM
ten.mile
Dec 11, 2012 05:56 PM
triggernut7788
36
Oct 12, 2011 08:39 AM
