New 302
Old Mar 28, 2011 | 08:57 AM
windsor357's Avatar
windsor357
New 302
OK I'm new and I'v never done anything like this but I just want some opinions. Recently i blew my 351 in my 1983 f150 it was bored .060 over forged crank, rods, and pistons. It had edelbrock heads, intake, cam and carb. MSD box, coil and distibutor. Then it had headers runnning into an h pipe and duals. It had a built C6 and I cant remeber the gears... like 3.70 or something anyways it dynoed at like 390 rwhp and 410 rwfpt. Well like i said it blew so i got a 302 out of a 87 f150 and basically dropped a new edelbrock intake and new distributor and the carb, headers and everything i could use from the 351 on the 302. I took all the smog **** off too. Im just wondering with the carb and intake and exhaust and all the smog gone along with all the MSD stuff what kind off hp and torque ill be getting.
Old Mar 28, 2011 | 09:07 AM
6CylBill's Avatar
6CylBill
About 110 hp and 245 ft lbs.
Old Mar 28, 2011 | 10:24 AM
windsor357's Avatar
windsor357
So basically no gain
Old Mar 28, 2011 | 12:12 PM
6CylBill's Avatar
6CylBill
I was joking, Amigo.
Is the 302 Fuel Injected or no? The Carb'd 302's made 130 horse and 250 ft lbs of torque. EFI made closer to 180 horse and 280 ft lbs.
Old Mar 28, 2011 | 01:27 PM
windsor357's Avatar
windsor357
Well it was originally efi but we put a edelbrock carb and intake and some hedman headers and and it's just duals into an h pipe and dumps but it's got like a full MSD ignition setup and it had the tow package don't know if that helps
Old Mar 28, 2011 | 01:28 PM
windsor357's Avatar
windsor357
And I tore off all the smog stuff
Old Mar 28, 2011 | 02:20 PM
6CylBill's Avatar
6CylBill
I don't know man. I don't know what happens when you remove EFI.
Best thing for you to do if you really want to know if spend the money and run her on a dyno. I for one would love to see the results!
Old Mar 28, 2011 | 04:17 PM
windsor357's Avatar
windsor357
I need to throw those 351 heads on there and get a decent cam and probably new pushrods and lifters and then I would be in really good shape lol
Old Mar 28, 2011 | 05:11 PM
6CylBill's Avatar
6CylBill
Why didn't you find another 351?
Old Mar 28, 2011 | 07:48 PM
windsor357's Avatar
windsor357
Well that 87 I found had 40000 original miles and it was only 200 bucks for the whole truck I just couldn't refuse
Old Mar 28, 2011 | 07:58 PM
6CylBill's Avatar
6CylBill
Built 302's are bad but don't expect it to be as bad as the larger V8 you had. As long as you keep that in mind you'll be happy.
I'm going to price crate engine 302's here in a minute. Sometimes I have to remind myseld why I don't buy crate engines. Ford crate engines are so expensive it's nuts.
Old Mar 28, 2011 | 09:11 PM
windsor357's Avatar
windsor357
I know it's crazy
Old Mar 28, 2011 | 09:29 PM
6CylBill's Avatar
6CylBill
That's why everyone uses GM 350 crate engines. Good power for half the price of a smaller Ford smallblock.
It's stupid!
So do you plan on putting your truck on a Dyno?
Old Mar 28, 2011 | 09:35 PM
KevinGnWV's Avatar
KevinGnWV
The village idiot.
Hard to say without being more specific on your parts. Heads, cams and intakes as you probably know can vary in how they perform by design. Some make low end torque, some make high end horsepower, some do a good job of balancing both, and matching all of these components to compliment each other is important.
The old saying is coming to mind right now. There's no replacement for displacement. Your going from a bored out 351 to a stock 302. I wouldn't expect miracles.
Old Mar 28, 2011 | 10:47 PM
6CylBill's Avatar
6CylBill
Pshhh, Mr. Kevin. He doesn't know what he's talking about. A stock 302 can chew up the beefiest of big blocks.
What's up Kev!?
