Spot the Difference
Old Mar 27, 2011 | 02:26 PM
lexustbs's Avatar
lexustbs
Spot the Difference
I was looking through old post and came across this picture. See what changes you can find from this picture to the actual production truck...
http://blogs.cars.com/.a/6a00d83451b...314d970b-800wi
Old Mar 27, 2011 | 02:32 PM
Marauder92V's Avatar
Marauder92V
Hill Descent & TCS shutoff buttons are missing. Some other button on the driver side below the power outlet.
Old Mar 27, 2011 | 02:34 PM
lexustbs's Avatar
lexustbs
They are behind the gearshifter. Look closely. i think that one button is to turn off and on the rear park aid?
Old Mar 27, 2011 | 04:29 PM
Chep's Avatar
Chep
Yeah TCS and Hill descent definitely look like they are above the shift on the fly and below the drivers side right vent. Information centre looks different. Vent bezel looks different, smooth instead of the gear look? Same great looking limited seats though.
Old Mar 27, 2011 | 05:13 PM
kper05's Avatar
kper05
Chrome vent outline doesn't look notched but is smooth.
Yes, that row of buttons/airbag off light (rc, sc) are moved to behind the column shifter.
I can't figure out what that round button is by the driver 12v dc socket.
This looks like the 6.2L model.
Can't tell if the manual +/- buttons are on the shifter (wouldn't think they would change that).
On one hand, I like that those buttons are closer to the driver now but could be difficult to push if the shifter is in the way.
If that truck is in Park now, then the buttons would be above the shifter if in [D] or [M] so that should be a nice change.
Old Mar 27, 2011 | 05:21 PM
Lurker1's Avatar
Lurker1
I think it's the pedal adjustment button.
Old Mar 27, 2011 | 07:33 PM
kper05's Avatar
kper05
I don't have that feature but it's currently on the left side of the steering column, correct?
Old Mar 28, 2011 | 05:43 AM
ruschejj's Avatar
ruschejj
Pedal adjustment is on the steering column, bottom left side.
Old Mar 28, 2011 | 12:51 PM
FourOneTons's Avatar
FourOneTons
It's got limited edition seats.
Joe
Old Mar 28, 2011 | 03:21 PM
Sportscraft's Avatar
Sportscraft
I second that its the pedal adjustment button next to the 12v. I also saw an early realease picture that had a F450 badge but no fender flares. Either an unprotected wide track axle or they had a 350 axle under it.
