05 headlight grille conversion
Old Mar 27, 2011 | 11:18 AM
CrzHelm's Avatar
CrzHelm
Im looking to 05 upgrade my ex and have 2 questions:
1) I see on ebay they have 05 looking headlights that swap right in but the edge between the light and grille is curved so i want to use actual 05 lights with the straight edge along the grille. I know some header panel trimming is involved to mount them but my question is.. are the bulb harnesses the same or do I need some extra parts there?
2) now for the grille... Im keeping my bumper so i have to buy a pretrimmed grille or trim it myself. If I trim it myself is there any mounting problems that Im going to run into?
and 1 more.... I cant decide whether to go with a chrome grille or paint it brown to match truck???? I could also paint both bumpers to match lower cladding.
thanks
Old Mar 27, 2011 | 11:40 AM
megawatt00's Avatar
megawatt00
The bulbs are different but an adapter or a conversion harness is readily available too. You do have to cut some of the header panel out but with a roto zip it goes very easily. As far as cutting the grills down it is very easy to do. I used the roto zip with a cutting disc on it. The important thing is to take your time and mask it off very carefully to give you a nice clean cut. I have cut down 4 or 5 of them IIRC.
Old Mar 27, 2011 | 12:15 PM
High Intentions's Avatar
High Intentions
Mod Specialist ;)
I have the 05 looking headlights. There are nice. The fact that you don't have to cut any of the support for the headlight and you use the factory light bulb makes it very easy to install.
Old Mar 27, 2011 | 02:59 PM
labman1014's Avatar
labman1014
I'm looking at a set on eBay that come with the adapters for the lights.
Old Mar 27, 2011 | 05:34 PM
megawatt00's Avatar
megawatt00
Eric is the header panel different from the EX and the Super Duty? I installed 05 Harley lights on my SD and I had to trim the header panel.
Old Mar 27, 2011 | 07:22 PM
CrzHelm's Avatar
CrzHelm
I just ordered the 05 grille and the 05 lights which came with the bulbs and harness adapters. you need to be careful some of these lights are curved and some are straight on the sides. It wouldve pissed me off after spending the money and finding the seams were all crooked. Its hard to see but the 05 grille has a straight side and 99-04 grilles are curved. you can see in some photos.
Also I hope after trimming the bottom of the 05 grille it dont effect any mounting tabs. I still havent gotten an answer on that.
Old Mar 27, 2011 | 07:30 PM
High Intentions
Mod Specialist ;)
Jim they are the same I beleive.
Old Mar 27, 2011 | 08:39 PM
labman1014's Avatar
labman1014
I plan in getting the pretrimmed grille from eBay. And yes I know about the side of the lights. Like u I will do both at the same time.
Old Mar 27, 2011 | 08:50 PM
TYZ78F150's Avatar
TYZ78F150
What/where are these 05' "looking" headlights that don't require trimming and take the 9007 bulb? I'm very interested.
Old Mar 27, 2011 | 08:53 PM
megawatt00's Avatar
megawatt00
https://www.ford-trucks.com/forums/7...a-99-04-a.html
Start at post 7 and there are the instructions on how to cut the grill.
Old Mar 28, 2011 | 04:03 AM
High Intentions
Mod Specialist ;)
tyz78f150, go to ebaymotors and do a sreach for excursion or superduty headlights. go to my gallery to see what they look like.
Old Mar 28, 2011 | 11:14 PM
Peace2Peep's Avatar
Peace2Peep
I've got a set of real 2005 headlamps for sale if anyone's interested. $200 shipped.
Old Mar 30, 2011 | 08:30 AM
TYZ78F150's Avatar
TYZ78F150
Are they new or used? Do they come with the adapters for the 9007?
Old Mar 30, 2011 | 09:32 AM
Peace2Peep's Avatar
Peace2Peep
Used off of my 2005 excursion. No adapters just the headlamps assemblies. Factory ford part, no aftermarket junk. Pm me and I'll fill you on any more details you need.
Old Mar 30, 2011 | 11:43 AM
nickyhatch's Avatar
nickyhatch
i just did the swap on my 2000. i opted to spend some money and get a pre cut grille.. couldnt be happier here is the company i used Chrome Ford Super Duty/Excursion Grille Conversion they actually cnc cut it .. the grille is 100%mint looks great easy install.. as far as the headlights i got the stock brand new 05 headlights.. trimming was really easy like butter with a body saw.. and i optd to go with 6 HIDs so i honestly didnt need a new 9008 plug.. just power ground with some quick connectors for removal
