RoughContry 4.5" Need help!
Old Mar 27, 2011 | 09:49 AM
viktar tuleika's Avatar
viktar tuleika
So i been trying to research a ton of info and didnt see any revew on 4.5 RoughCountry 4.5 lift kit ? I dont think i like the spacer in the front ,so i think get taller front springs and sell mine maybe .I allready have Prorated front springs ,so my nose looks like it level with back.Any one out there has this set up installed ? Is it good kit ? or its a waste of money ? im thinking 295/70/18 on stock rim with it.Also going to add a leaf in the back.
Please give me some advise ,I dont want to F... Up $55 K truck !
Thanks!
Old Mar 27, 2011 | 10:28 AM
My Skilz's Avatar
My Skilz
You won't need to go that tall on a lift kit ,a simple leveling or i used a 2.5 kit which is plenty of room . that size tire is only 1 inch taller and less than 3/4 of a inch wider ...i went with the nitto tera grappler, great tire <TABLE style="BORDER-COLLAPSE: collapse" borderColor=black cellSpacing=0 cellPadding=4 background=images/spacer.gif border=1><TBODY><TR bgColor=#d3d3d3><TD>Stock Tire - 275/70R18 >Search Tires </TD><TD>Tire 2 - 295/70R18 >Search Tires </TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'; window.status='Section Width: the width of a tire; the width at its widest point from sidewall to sidewall.';" style="BACKGROUND-COLOR: #ffffff" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=100>Section Width:</TD><TD align=right width=80>10.82 in</TD><TD align=right>275 mm</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Section Width:</TD><TD align=right width=80>11.61 in</TD><TD align=right>295 mm</TD></TR></TBODY></TABLE></TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'; window.status='Rim Diameter: height of the wheel this tire will fit on';" style="BACKGROUND-COLOR: #ffffff" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=100>Rim Diameter:</TD><TD align=right width=80>18 in</TD><TD align=right>457.2 mm</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Rim Diameter:</TD><TD align=right width=80>18 in</TD><TD align=right>457.2 mm</TD></TR></TBODY></TABLE></TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'; window.status='Rim Width Range: recommended rim widths that this tire will fit on';" style="BACKGROUND-COLOR: #ffffff" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width="100%"><TBODY><TR><TD width=100>Rim Width Range:</TD><TD align=right width=160>Unrecognized tire size.</TD></TR></TBODY></TABLE></TD><TD><TABLE width="100%"><TBODY><TR><TD width=100>Rim Width Range:</TD><TD align=right width=160>Unrecognized tire size.</TD></TR></TBODY></TABLE></TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'; window.status='Diameter: overall height of the tire';" style="BACKGROUND-COLOR: #ffffff" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=100>Overall Diameter:</TD><TD align=right width=80>33.15 in</TD><TD align=right>842.01 mm</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Overall Diameter:</TD><TD align=right width=80>34.25 in</TD><TD align=right>869.95 mm</TD></TR></TBODY></TABLE></TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'; window.status='Sidewall: the height of one tire sidewall';" style="BACKGROUND-COLOR: #ffffff" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=100>Sidewall Height:</TD><TD align=right width=80>7.57 in</TD><TD align=right>192.27 mm</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Sidewall Height:</TD><TD align=right width=80>8.12 in</TD><TD align=right>206.24 mm</TD></TR></TBODY></TABLE></TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'; window.status='Radius: height from the center of the tire to the outside edge';" style="BACKGROUND-COLOR: #ffffff" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=100>Radius:</TD><TD align=right width=80>16.57 in</TD><TD align=right>420.87 mm</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Radius:</TD><TD align=right width=80>17.12 in</TD><TD align=right>434.84 mm</TD></TR></TBODY></TABLE></TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'; window.status='Circumference: distance around the outside edge of the tire';" style="BACKGROUND-COLOR: #ffffff" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=100>Circumference:</TD><TD align=right width=80>104.1 in</TD><TD align=right>2644.1 mm</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Circumference:</TD><TD align=right width=80>107.5 in</TD><TD align=right>2730.5 mm</TD></TR></TBODY></TABLE></TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'; window.status='Revs per Mile: number of times this size tire rotates when travelling one mile';" style="BACKGROUND-COLOR: #ffffff" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE><TBODY><TR><TD width=100>Revs per Mile:</TD><TD align=right width=130>627.4</TD></TR></TBODY></TABLE></TD><TD><TABLE><TBODY><TR><TD width=100>Revs per Mile:</TD><TD align=right width=130>607.2</TD></TR></TBODY></TABLE></TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'; window.status='Speedometer: speedometer readings when travelling at 60mph / 100km/h';" style="BACKGROUND-COLOR: #ffffff" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=120>Actual Speed:</TD><TD align=right width=80>60 mph</TD><TD align=right>100 km/h</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Speedometer1:</TD><TD align=right width=80>58.0 mph</TD><TD align=right>96.7 km/h</TD></TR></TBODY></TABLE></TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'" style="BACKGROUND-COLOR: #ffffff" onmouseout="style.backgroundColor='#FFFFFF'"><TD bgColor=#eeeeee>Speedometer Difference: -</TD><TD>Speedometer Difference: 3.326% too slow</TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'" style="BACKGROUND-COLOR: #ffffff" onmouseout="style.backgroundColor='#FFFFFF'"><TD bgColor=#eeeeee>Diameter Difference: -</TD><TD>Diameter Difference: 3.22%</TD></TR></TBODY></TABLE>
Old Mar 27, 2011 | 10:36 AM
viktar tuleika
Originally Posted by My Skilz
You won't need to go that tall on a lift kit ,a simple leveling or i used a 2.5 kit which is plenty of room . that size tire is only 1 inch taller and less than 3/4 of a inch wider ...i went with the nitto tera grappler, great tire <TABLE style="BORDER-COLLAPSE: collapse" border=1 cellSpacing=0 borderColor=black cellPadding=4 background=images/spacer.gif><TBODY><TR bgColor=#d3d3d3><TD>Stock Tire - 275/70R18 >Search Tires </TD><TD>Tire 2 - 295/70R18 >Search Tires </TD></TR><TR style="BACKGROUND-COLOR: #ffffff" onmouseover="style.backgroundColor='#D3D3D3'; window.status='Section Width: the width of a tire; the width at its widest point from sidewall to sidewall.';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=100>Section Width:</TD><TD width=80 align=right>10.82 in</TD><TD align=right>275 mm</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Section Width:</TD><TD width=80 align=right>11.61 in</TD><TD align=right>295 mm</TD></TR></TBODY></TABLE></TD></TR><TR style="BACKGROUND-COLOR: #ffffff" onmouseover="style.backgroundColor='#D3D3D3'; window.status='Rim Diameter: height of the wheel this tire will fit on';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=100>Rim Diameter:</TD><TD width=80 align=right>18 in</TD><TD align=right>457.2 mm</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Rim Diameter:</TD><TD width=80 align=right>18 in</TD><TD align=right>457.2 mm</TD></TR></TBODY></TABLE></TD></TR><TR style="BACKGROUND-COLOR: #ffffff" onmouseover="style.backgroundColor='#D3D3D3'; window.status='Rim Width Range: recommended rim widths that this tire will fit on';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width="100%"><TBODY><TR><TD width=100>Rim Width Range:</TD><TD width=160 align=right>Unrecognized tire size.</TD></TR></TBODY></TABLE></TD><TD><TABLE width="100%"><TBODY><TR><TD width=100>Rim Width Range:</TD><TD width=160 align=right>Unrecognized tire size.</TD></TR></TBODY></TABLE></TD></TR><TR style="BACKGROUND-COLOR: #ffffff" onmouseover="style.backgroundColor='#D3D3D3'; window.status='Diameter: overall height of the tire';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=100>Overall Diameter:</TD><TD width=80 align=right>33.15 in</TD><TD align=right>842.01 mm</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Overall Diameter:</TD><TD width=80 align=right>34.25 in</TD><TD align=right>869.95 mm</TD></TR></TBODY></TABLE></TD></TR><TR style="BACKGROUND-COLOR: #ffffff" onmouseover="style.backgroundColor='#D3D3D3'; window.status='Sidewall: the height of one tire sidewall';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=100>Sidewall Height:</TD><TD width=80 align=right>7.57 in</TD><TD align=right>192.27 mm</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Sidewall Height:</TD><TD width=80 align=right>8.12 in</TD><TD align=right>206.24 mm</TD></TR></TBODY></TABLE></TD></TR><TR style="BACKGROUND-COLOR: #ffffff" onmouseover="style.backgroundColor='#D3D3D3'; window.status='Radius: height from the center of the tire to the outside edge';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=100>Radius:</TD><TD width=80 align=right>16.57 in</TD><TD align=right>420.87 mm</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Radius:</TD><TD width=80 align=right>17.12 in</TD><TD align=right>434.84 mm</TD></TR></TBODY></TABLE></TD></TR><TR style="BACKGROUND-COLOR: #ffffff" onmouseover="style.backgroundColor='#D3D3D3'; window.status='Circumference: distance around the outside edge of the tire';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=100>Circumference:</TD><TD width=80 align=right>104.1 in</TD><TD align=right>2644.1 mm</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Circumference:</TD><TD width=80 align=right>107.5 in</TD><TD align=right>2730.5 mm</TD></TR></TBODY></TABLE></TD></TR><TR style="BACKGROUND-COLOR: #ffffff" onmouseover="style.backgroundColor='#D3D3D3'; window.status='Revs per Mile: number of times this size tire rotates when travelling one mile';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE><TBODY><TR><TD width=100>Revs per Mile:</TD><TD width=130 align=right>627.4</TD></TR></TBODY></TABLE></TD><TD><TABLE><TBODY><TR><TD width=100>Revs per Mile:</TD><TD width=130 align=right>607.2</TD></TR></TBODY></TABLE></TD></TR><TR style="BACKGROUND-COLOR: #ffffff" onmouseover="style.backgroundColor='#D3D3D3'; window.status='Speedometer: speedometer readings when travelling at 60mph / 100km/h';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=120>Actual Speed:</TD><TD width=80 align=right>60 mph</TD><TD align=right>100 km/h</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Speedometer1:</TD><TD width=80 align=right>58.0 mph</TD><TD align=right>96.7 km/h</TD></TR></TBODY></TABLE></TD></TR><TR style="BACKGROUND-COLOR: #ffffff" onmouseover="style.backgroundColor='#D3D3D3'" onmouseout="style.backgroundColor='#FFFFFF'"><TD bgColor=#eeeeee>Speedometer Difference: -</TD><TD>Speedometer Difference: 3.326% too slow</TD></TR><TR style="BACKGROUND-COLOR: #ffffff" onmouseover="style.backgroundColor='#D3D3D3'" onmouseout="style.backgroundColor='#FFFFFF'"><TD bgColor=#eeeeee>Diameter Difference: -</TD><TD>Diameter Difference: 3.22%</TD></TR></TBODY></TABLE>
The reason i want a lift kit is get my rear up a little ,my truck sits level right now ,cause i have plow prep package ,that gave me 1 1/2 higher front springs,so if i go another 2" up on the front its gonna look like crap Plus i dont know if i like a spacer ,so I was thinking taller spring and like 5" ready lift block on rear with add a leaf ? so the bed gonna look up a little .My trailer over 14000 lb ,its no joke how much my rear sag is ...
Old Mar 27, 2011 | 10:41 AM
My Skilz's Avatar
My Skilz
I also have the plow pack. truck sat level i added the 2.5 and front came up about 2 inch and rear blocks were almost 2 inches thick brought rear up 1 inch higher than front ,for a little rake i thought it looks good also i have air lift air bags in rear for when i tow tuck is always level never a sag ..
Old Mar 27, 2011 | 10:42 AM
My Skilz's Avatar
My Skilz
Only difference in our trucks is I have the gas model ..
Old Mar 27, 2011 | 10:56 AM
viktar tuleika
So you did add a block on rear ? Can you post picture ? what it looks like ?
Old Mar 27, 2011 | 11:05 AM
My Skilz's Avatar
My Skilz
I dont have pics yet of my truck but the block comes with most all kits and goes between the axle and factory block, and longer u bolts simple install..i will take some pics as soon as i can ..
