1966 - 1977 Early Broncos
69 Coyote Swap
Old Mar 27, 2011 | 07:23 AM
1969 Bronco Coyote's Avatar
1969 Bronco Coyote
Exclamation 69 Coyote Swap
I want to be one of the first to get this engine in an old Bronco. Need some help! Right now we are going with the 5.0 and the necessary additions from ford for the engine (wiring harness, alternator, oil filter relocation brackt). We have a used transmission (an AODe off of a 2004). We are planning on buying an aftermarket controller for the trans and an Altas transfer case. Anybody done this yet? Any suggestions?
Old Mar 27, 2011 | 09:29 PM
Boba Fett's Avatar
Boba Fett
why bother? you need a body lift... and after all that money and trouble you could have installed a 408 windsor stroker motor running fast efi and have something....
Old Mar 28, 2011 | 07:02 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Haven't heard of anyone attempting it yet, but I'm sure it will be done. Check over on classicbroncos.com Lot of members dealing only with EB's so a vast amount of knowlege to be had.
Old Mar 28, 2011 | 07:46 AM
1969 Bronco Coyote
I don't know why. Maybe modern engine, modern trans, better fuel mileage, something no one has done. I am not planning a body lift. Stroker's are nice engines, don't get me wrong, just wanted the challenge.
Also, I have a buddy with a coyote in a a/c cobra replica and it has a unique unheard sound that would be impressive in a bronco. All the rest sound like old technology.
Old Mar 28, 2011 | 07:54 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
It's still a fairly new engine and expensive. I'm sure there will be more as time passes. Bronco owners love to modify them and just about every combination has been done. It's just a matter of available funds and planning. Only research will tell what modifications will be needed. Go for it, and post a build thread as you go.
Old Mar 28, 2011 | 10:31 AM
chrlsful's Avatar
chrlsful
Not sure the Q except being general in nature. Sorry a general answ is offered. U could tell us what U want to use it 4 to get more specific feedback.
Welcome to the site and esp this forum! Stick around, lotta great guys (U colud join ur local Chapter & meet up w/locals as I do. We get together often for "adult male entertainment") ;- }
1) the Ford AOD or the Chebby 700R4 are both options that you can look in to.
Either is somewhat of a pain..requires adapters and custom cross-member...different drive shafts.
2) Another AOD
I have a Lentech RV2000 AOD with low gearset in my Bronco It has worked
very well for me for ~5 years (granted the past 2 it has barely left the
garage). The only issue I would say I have with it is that due to the
throttle position needed to run down the highway with traffic (~75-80mph)
the OD rarely kicks in with the throttle cable adjusted properly (35"
radial street tires, 4.88's in the axles). Around town and cruising up to
50mph it is very nice having the OD though. The only other part I don't
like about AODs in general is the OD is a band rather than gearset, so it
will be more prone to wearing out; however I have yet to talk to someone
who has worn an aftermarket HD one out that had the throttle cable adjusted
properly.
At 08:07 PM 10/3/2005, Karl Bradley wrote:
>All,
> After getting tired of looking and on for nearly a year at over
> priced junk ebs for my wife we have finally decided to restore my '66
> this winter which is sitting in the back of the garage in the same
> location since '99! The gameplan is pretty well established-motor,
> axles, interior etc except for the tranny. My "C4 guy" is in his 50's
> and would rather not do an AOD(kind of set in his ways!!).
> I have a line on a 700R4 adaptor for the small block but would
> rather not sin against the blue oval. The NV3500 series will not handle
> the motor we are building(hope she lets me drive it some and I do not
> want to put a body lift on it to install an NV4500 series.
>SO......any recs. on a GOOD AOD builder preferrable east of the Miss.? I
>have looked through the various 'stang rags and am familiar with some of
>the named AOD builders. Was hoping someone had some experience first hand
>instead of calling one of the "named" builders cold.
>TIA,
>Karl Bradley
>ebsss
Old correspondence on ECBR (2 or 3 of em).
All depends on application, application, application. I'm gunna try a 250/4.1 I6 in my lill bobtail (use 4 wrk not recreation), oem trani/transfer. Dream: ZF for the 2 PTOs n a lower 1st/add a 5th on top).
cb dot com is good to explore as suggested above by gfw1985 (Hi Richard. got 2 days of wrk, over now). just pull in ur ears 1st, lotta egos over there. I'd recomend the C4 due to the lack of power it robs, but again, don't know ur application (that's the whole automotive story if U ask me).
Old Mar 28, 2011 | 11:43 AM
1969 Bronco Coyote
I really appreciate the feedback. I have a interesting situation in that my business is in the automotive area, so I can get parts much cheaper and utilize 160 technicians to do the work. What we need is some help with the initial decisions. All feedback is welcome. Thanks.
Old Mar 28, 2011 | 11:55 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Oil pan clearance/design and bolt pattern for bell housing are the first things I'd look into. You can make anything fit, especially if you have the resources to fab adapters.
Old Mar 28, 2011 | 04:36 PM
chrlsful's Avatar
chrlsful
Didn't say "machine shop" Richard...
Again, what;s the application mall crawler, rat rod, street racer, mud racer, multipurpose, rock crawler...it all comes from there...a clear goal of use develops backwards to each component creating that consistant well designed whole...
I think I'll make a Bronco plane, er, no ahh...JET, yeah, that's it! A Bronco jet, Y not?
Sorry, supposed to B a joke.
(but let's C...umm 30,000 lb thrust rocket outta do it, humm
Old Mar 28, 2011 | 04:49 PM
1969 Bronco Coyote
I really want a daily driver. Will use it at the beach as well. Thinking of over the top paint as well. Coyote theme.
Old Mar 28, 2011 | 05:10 PM
chrlsful's Avatar
chrlsful
reliability and inexpensive comes to MY mind when U say that...nothing wrong w/the orig 170/200 (may B the 144 for even better gas mileage?). I like ur auto (aod) idea, or a 5 speed. "the beach" doesn't mean much 2 me unless U say "dune jumpin". Again the 170 (I skid 18"X 25 ft logs up steep hills w/mine, plow heavy wet sno, etc) is fine w/31" tires the oem 3 speed and 4:11 rear (rear gear - that's the trick I'm sure) for a lill heaver sand running. Where would that B? No info on ur sig or post. Just get some tires U can air down so as they grip/not dig in/will 'float' but still don't loose a bead @ 7 - 12# psi. Or the expensive single use "paddle tires". I want bead locker I can run on my 'wagons' and a off rd/street tires (like the BFG's TA/KO). May have to get a better wheel tho, just like the "wagons" look. Bud wheel is my fave for looks and everything else (but weight).
So dream on, enjoy, stay in touch.
Old Mar 28, 2011 | 06:19 PM
1969 Bronco Coyote
I will make sure to post our parts list in the next couple of days. I would like to use the vehicle often. I have 4 girls in soccer, field hockey, horse back etc. and want to be their designated driver with this Bronco. Duck hunting with my 2 labs and surf fishing in North Carolina will be the heaviest action this Bronco will see.
Keep the feedback coming. I will be sure to document what we do.
Old Mar 28, 2011 | 07:16 PM
chrlsful's Avatar
chrlsful
post our parts list
Pic is what we (I) seek! In fact get 1 out as she sits now if U will! (o0OPPps, u may hafta wait till U got 25 posts or sompin, it's been awhile, forget now).
Again join the local, there's P L E N T Y of EBs in ur area! In fact KB is from there & in the last Bronco Driver mag. I cited his name in my other email above - C '2005' above).
The dog the girls...U got to get a bigger rig. Bronks R 4 low numbers...I call mine a 'personal' vehicle. ;-}
Old May 3, 2011 | 10:09 PM
Mustangtoby2001's Avatar
Mustangtoby2001
Real curious to see how this turns out. I would look into the oil pan (I know the 5.0 comes in the new f150, but don't know if it has a rear sump pan). May be a non issue, but where I would start. Figure out the tranny, and work from there. Should be a powerhouse, and the aftermarket should get big for it over the next couple of years if you want more power.
There has been everything from cummins swaps to a 7.3 powerstroke put in one of these, not to mention Triton motors are starting to get popular. The Coyote is pretty similar to the Triton (bell housing bolt pattern and physical size), so it should be doable with enough determination. Lets see some pics!
Old May 4, 2011 | 08:02 AM
1969 Bronco Coyote
We need to get to 25 posts then I can put pics up. Right now we are going with an AODe trans w/ nods to handle 600 HP and an Atlas 2 transfer case. I am not going to go to 600 HP but the choice later and durability now matter to me. We will know more about the oil pan in the next couple of weeks.
