Suspension Fix Questions
Old Mar 28, 2011 | 02:42 PM
twtcad's Avatar
twtcad
Ok.....can you guys help clear this up for me?
I've read so many different versions of the spring swaps; X, W, V & modified.....I see from this thread the V should give you 1.75" of lift and the modified B's 1.5" of lift. How much do the X & W give you and is one better than the other or should I be looking at which one's I can get the best price on? Oh, I'm going for ride comfort....rarely tow. Thank you!
Old Mar 29, 2011 | 08:49 PM
HDBiker67's Avatar
HDBiker67
Well, got the anti sway bar installed today. It went fairly well.
Originally Posted by WE3ZS
...Save yourself a trip under and back out, before you start the install drill out the holes in the new mounting plates so they are big enough to fit the supplied U-bolts through....
Hey, WE3ZS, Hellwig must have listened to all those complaints, I didn't have to drill out those holes. The U-bolts fit fine.
It does make a big difference, however I still get some travel, so I think I am gonna get the toe checked on the alignment.
I talked to a guy at a 4wd specialty shop this afternoon too. I think I might start a new thread on that subject. Long story short, what he said is contrary to what I have read here, but although he has been in business 30 some years I don't quite think he is right. I just want to share what I heard, maybe it will help others too.
Old Mar 29, 2011 | 09:11 PM
HDBiker67's Avatar
HDBiker67
Ok, as noted above, I started a thread about the discussion I had with a local shop that recommended add a leaf
hope I do this right...
here is a link ( I hope )
V/B spring mod vs add a leaf
MK_snipe
Apr 5, 2016 04:40 PM
Sous
Jun 2, 2015 12:08 AM
exbxtoy
Apr 10, 2014 05:44 PM
buickbuggy
Feb 1, 2013 01:05 PM
MarkMoore
Apr 14, 2008 04:55 PM
