Sponsored by: Real Truck
Occasional Issue at Startup
Old Mar 26, 2011 | 11:21 PM
jd1083's Avatar
jd1083
Like the title says my '01 F250 5.4L occasionally acts weird when I first start it up. It starts fine but immediately drops to 500 RPMs. Every once in a while it will sit at 500 RPM for a second or two then race up to around 1500-1800 RPMs then drop back down to the normal 1000 RPM, but sometimes it will stay idling at 500 RPMs and run a little strange for a few mins. What could be causing this?
Old Mar 27, 2011 | 10:19 AM
jh818's Avatar
jh818
Check IAC valve?
Old Mar 28, 2011 | 07:15 PM
ddesens's Avatar
ddesens
Check for broken or cracked vacuum lines on the intake manifold also. Pcv valve new?
Old Mar 28, 2011 | 09:22 PM
jd1083's Avatar
jd1083
I checked most of the vacuum lines and they're all in good shape, haven't gotten to check the IAC valve yet. The truck runs fine besides the occasional strange issue at startup. I'm leaning towards the IAC but a local mechanic said that if the IAC were bad that it would throw a code and cause the SES light to come on, and it hasn't come on yet.
kmaddentx
Apr 8, 2012 11:36 AM
mhenneboehle
15
Nov 8, 2010 10:32 PM
jeffhead
13
Jan 23, 2008 10:14 PM
jeffhead
Jan 22, 2008 09:48 PM
Scrapiron66
Jan 21, 2004 02:53 PM
