1999 f150 4x4 5.4 triton when plugged in got P code for tcc solenoid to be changed. tcc solenoid was changed trans. fluid and filter. on test run truck now shaking does anyone have any ideas what may be going on. tks. for any help
Reason: more truck info. added
Just off hand, did you or someone else match up the new filter with the old ? The reason I ask is, I had a '94 ( I know, different forum) that I bought new. Any time I had to do trans maintenance, half the parts didn't fit right. If the new stuff was matched to the trans tag, it might not be that, but if it was just picked out of a catalog, the wrong filter might be the problem.
My '94 came with a '92 transmission, and I bought the truck new.
In any event, it sounds like a fluid problem, either lack of volume or pressure. Also possible that the torque converter isn't filling up with fluid. Has the fluid level been checked again ?
