Help!!!! Identifing ford rear end
Old Mar 26, 2011 | 01:18 PM
19chevy46's Avatar
19chevy46
The metal plate on a ford rear end I am trying to buy is B16 6 4 11 B06
The man I am trying to buy it from can't help me out on the gears or anything else(like what it came out of)
Thank You
19chevy46
Old Mar 26, 2011 | 01:42 PM
lonnie1952's Avatar
lonnie1952
Thank You
19chevy46
Picture of rear end ?
Old Mar 26, 2011 | 03:31 PM
19chevy46's Avatar
19chevy46
No picture available
He does not have a photo. Been looking everywhere with that code number without any success
Old Mar 26, 2011 | 04:27 PM
lonnie1952's Avatar
lonnie1952
Have your buddy take a cell phone pic...send It to you...You post it
other-wise ............you might be out of luck
Someone will be able to identify it with a pic...the tag won't help much
Good Luck........
Old Mar 26, 2011 | 10:24 PM
85e150's Avatar
85e150
Integral carrier or drop out carrier?
5 lug, 6, 8, ??
Some hints here:
Axle/Differential Identification at http://www.4wheelnoffroad.com/
Old Mar 26, 2011 | 11:53 PM
fixnair's Avatar
fixnair
I would guess at 4.11 gears but then the rest of the tag does not look anything like Ford numbers. Go here and try to find those numbers. Are you sure it is a Ford 9"?
Ford Rear Axle Assembly Identification - Page 09 - FORDification.com
Old Mar 27, 2011 | 12:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
B16 6 4 11 B06 is a Carrier ID tag number. I could not find this exact number in any 1948/72 truck parts catalog but did find similar numbers that begin with either A16 or C16.
If this is a Ford rear axle (I have my doubts), it's prolly from an F350 or larger truck.
It's not an 8 or 9 (introduced 1957) inch drop out (which do not have an inspection cover).
The ID number does not match up to a Spicer-Dana 44 (F1/F100-5 lug, 5.50" bolt circle) or Spicer-Dana 60 (F250-8 lug, 6.50" bolt circle).
If 6 lug, 7.25" bolt circle: 1953/66 F350 Timken rear axle.
4 11 is prolly 4.11-1 / B06 could be the code for the date the axle was assembled: February (B), 1956 (6) for example.
Photos: It's difficult to tell an 8" from a 9" by looking at it. 8's were installed in mid-sized 1962/80 passenger cars.
