whats the cause?
Old Mar 25, 2011 | 07:33 PM
zakk's Avatar
zakk
whats the cause?
every morning when i cold start my truck it makes like a knock type noise after start up seems like the cylinder isnt fireing? its goes for about 20 seconds and then it runs fine after that. any one know whats wrong?
Old Mar 25, 2011 | 07:34 PM
zakk's Avatar
zakk
ill try and get a video
Old Mar 25, 2011 | 07:53 PM
Fordownsall's Avatar
Fordownsall
Well everyones noises are interpreted differently... but.. If your hearing a Piston slap type noise sounding hollow and bell-like during cold engine operation and louder at acceleration, you could have worn piston rings, worn cylinder walls, collpased piston skirts, misaligned connecting rods, worn bearings, excessive piston to wall clearance, or poor lubrication...
An imporant point to keep in mind is that insufficient lubrication is the most common cause of engine noise.. So check the fluid levels.
Some noises are more pronounced on a cold engine because clearances are greater when parts are not expanded by heat. Aluminum and iron expand at different rates as temperature rises. For example, a knock that dissappears as the engine warms up, is probably piston slap/knock. An aluminum piston expands more than the iron block, allowing the piston to fit more closely as engine temp. rises.
akamacgyver's Avatar
akamacgyver
Clueless spectator!
Knocking at start-up
Zakk,
I believe these trucks have a cold start timing compensator which causes the knocking. I believe it is set when the pedal is depressed to the floor after the key is turned on and before starting. Mine does the same thing. I think that is what you are hearing. My understanding is that this is normal. I am sure someone else will elaborate, who knows much more about it than I.
Old Mar 25, 2011 | 08:06 PM
zakk's Avatar
zakk
Originally Posted by akamacgyver
Zakk,
like the high idle for faster warm up or whatever? mine dosent work
Old Mar 25, 2011 | 08:08 PM
johnboggs21's Avatar
johnboggs21
Theirs a high idle and also a cold timing advance. The timing advance will make it sound more rattely kind of like a powerstroke
Old Mar 25, 2011 | 08:15 PM
GHeTTo JOe's Avatar
GHeTTo JOe
how about its not running on all 8? mine will do this i need to check all glow plugs again i think its just one cylinder not fireing till it warms up enough to
Old Mar 25, 2011 | 08:17 PM
zakk's Avatar
zakk
thats what i was guessing
Old Mar 25, 2011 | 08:26 PM
zakk's Avatar
zakk
here's a video i just took... not very good but you can hear the noise
Old Mar 25, 2011 | 09:01 PM
Fordownsall
yea i don't know sounds real distorted over the camera.. almost sounds exactly like my truck on a real cold start.. I don't know I think your best option is to have a well experienced diesel tech listen to it as well.
Old Mar 25, 2011 | 09:06 PM
wreckinball's Avatar
wreckinball
could be a sticking injector, could be air in the lines. hard to say.
Old Mar 25, 2011 | 09:34 PM
84-6.9L's Avatar
84-6.9L
When it does that try cracking injector lines and see if theres one where the noise doesnt change. Worth a shot at least
Old Mar 25, 2011 | 10:01 PM
josh'sdeisel's Avatar
josh'sdeisel
heck mine does it little but not that bad but i dont know do yall know anything bout breaks?
Old Mar 25, 2011 | 10:39 PM
zakk's Avatar
zakk
these people know everything just start a new thread asking your question
Old Mar 25, 2011 | 10:41 PM
BlueOvalBud's Avatar
BlueOvalBud
Josh, welcome to the IDI forum.
You'll have much better luck getting an answer is you start a new thread with a good title
Do you have a decent oil pressure gauge? Have you checked your oil level?
Seems like it's either taking a while to build oil pressure...
Or...it's taking a while to fire on all 8...
What temperature is it outside when you do this?
I don't think that's long enough for the cold timing advance...definetly not long enough for high idle. This week, my high idle has been taking 3 minutes or so to get up to temp and kick off. Colder weather, can be up to 5 or 6 minutes.
Mine sounds good instantly at start-up, but my fuel system only has 25k miles on it. Engine gets beaten daily though...
Mileage on the engine? Mileage on the fuel system?
