Torque specs
Old Mar 25, 2011 | 06:15 PM
JT250's Avatar
JT250
Torque specs
Doing injector o rings this weekend...found that you torque those to 120 inch lbs. What are the specs for the rocker arms?
Old Mar 25, 2011 | 06:21 PM
Ziggy.'s Avatar
Ziggy.
Rocker arms are 20ft lbs, good luck bro!
Old Mar 25, 2011 | 06:24 PM
JT250's Avatar
JT250
Thanks soggy just found your torque thread. Wonder why it doesn't come up when u search "torque"
Old Mar 25, 2011 | 06:27 PM
Ziggy.'s Avatar
Ziggy.
Maybe I need to edit the tags for it I guess
Old Mar 25, 2011 | 06:31 PM
JT250's Avatar
JT250
Hmmm "soggy" looks like the iPad corrected my spelling for me I know that said ziggy
Old Mar 25, 2011 | 06:35 PM
Ziggy.'s Avatar
Ziggy.
Lmao its all good Jason, I know what you meant.
Old Mar 25, 2011 | 08:42 PM
JT250's Avatar
JT250
Will I need to put any oil on the injector o rings or anything?
Old Mar 25, 2011 | 10:26 PM
Ziggy.'s Avatar
Ziggy.
Yea sure do, just lube them up with some good clean engine oil. If not you could pinch, roll, or break one, or it might be a SOB to seat properly too.
Old Mar 25, 2011 | 10:29 PM
JT250's Avatar
JT250
Thanks ....first time so gotta make sure I know what I'm doing
Old Mar 25, 2011 | 10:52 PM
Ziggy.'s Avatar
Ziggy.
It's not a bad job at all, when you pull them, pull #7 and 8 first, and let all of the oil and fuel go into those 2 cyl, and there will be hardly anything in the rest of the cylinders. And make sure the inj are seated all the way, other than that, you've got it whooped man.
