65 F100 4x4 got for parts only turns DD project
#91
Ill see if I can take some later and post them up. Havent done that yet but thats a good idea. The headers I used are flowtech. I got them from Jegs online. Had a little bit of a problem on the starter side had to bend in the bendix cover a little and dent the header a little. A smaller hitorque starter may have solved that problem. On the drivers side the clutch return spring bracket had to be moved back slightly to clear the header and it sits very close to the front driveshaft. Im sure when I take it for exhaust system the exhaust guy will know if that will fly and if not maybe he can correct that.
#92
Here are those pics.
There you have it this is what the headers look like from a squirrles eye view. Its hard to tell on the starter and the clutch linkage side as to fitment but there were a few issues. You tell me is the collector on the drivers side to close to the front drive line. I dont know. Never put headers on a 4wd vehical before. I will find out from the exhaust guy after the holidays.
#93
sorry but can't help much as to the headers my experiense is "0" in that regard but they do look very close to your front drive shaft. i know things can flex/move around a little when your going down the road if it were me i'd drive around and see how it goes (highly technical advice on my part).
kind of a spendy alternative but i've thought about the ram horn type headers for my 4x4 292. exhaust guy looked at the truck when i had it in the shop and said it would be a tight fit also so...?
#94
#95
#96
Yup Im thinking your right. I just want to keep them distant cousins. Not kissin cousins. Hoping my exhaust system guy will have a plan.
#98
Thanks Mitch Im kind of slowed up by the winter weather and the holidays. Not getting alot of help from my son right now as he is busy getting himself enrolled in collage and finding a place to live down at WSU. Ill let him know what you said. I got the trans shifter back from the fab shop but it was not quite bent enough to clear the transfercase shifter so back to the fab man for more bending. When I get the shifter so everything is copastetic ill make him street legal. Then its off to the muffler man for some quieter breathing tubes. Probably post up some more pics at the start of the new year if there is more progress by then.
#100
Yeah it was rough but Ive seen worse on FTE. Ive just been holding on to enough parts through the years to just about build another truck. Good thing is now Ill have a little more room in my garage. You will probably have to stick around for the complete finish. This is just about as far as it goes as I have a 63 to get back to work on. When the 63 is complete then the 65 will get the full frame off. This was kind of a hit it and get it type resto. Thanks for the props. I just replaced the rear pinion seal at the rearend it had a bad leak. I have one more seal to replace on the TC it is the front drive shaft output seal it leaks real bad. I have to get a proper size socket to undo the yoke. All the tools and didnt have a socket the proper size. Damn Fords.
#101
#102
#104
That's funny! I usually say that about chrysler engineers/designers! I've worked on a lot of Caravan/Voyagers. So I've done a lot of cussing and throwing tools, while threatening bodily harm to any chrysler engineer I ever can get my hands on!!!
#105
We owned a 77 plymoth volarie once. That was my first and last Chrysler product. Take what you just said and multiply by 10. It left such a bad taste in my mouth I swore no more Dodge or Chrysler period. You cant even pay me to own one. Even if you are paying me I figure it would end up costing me somehow.
