Sponsored by: Real Truck
Coolant Flush Question
Old Mar 26, 2011 | 11:42 PM
Javo's Avatar
Javo
Originally Posted by Kajtek1
I am not sure about purified water. The reverse osmosis from what I learned gets pretty close to distillate water, but typical softeners get water softer by replacing calcium with sodium. That from what I have been told can be harmful to cooling system.
You are correct. Reverse Osmosis uses a filtration method where impurites are actually removed (up to 99.9%) and softeners use an ion exhcange process. Softened water is good for washing your car, not your coolant mix. I tested my reverse osmosis water before using yesterday and I had 2ppm TDS (parts per million Total Dissolved Solids) - plenty pure enough for a coolant mix IMHO.
golfnut324
Jan 3, 2017 08:54 AM
akblackfoot
Apr 6, 2016 05:26 PM
SC_Dave
Oct 12, 2015 10:39 AM
dirtriderdan
Nov 23, 2009 09:30 AM
kevin.ford-trucks
Jun 20, 2009 02:24 PM
