Sadly boy's, and I do mean sadly.........I'm not going to make it. I need to save ALL my extra money for the rear end mod that's coming. Gears, master install kit, misc. parts, and TRUTRAC!
that is all.
I have a front axle for you if you want out of my 99. You can have it this weekend, and it is complete hub to hub.
Depends on how much you want for it... Is the spring spacing the same between the OBS and SD? If I swapped in that axle I'd have two different wheel bolt patterns front/rear.
