I don't know what to say...........after changing out the ball joints and multiple front end parts on Ron's truck, we pulled my rear brakes to try and find out the source of a strange noise. Disconnected the driveline, still making the noise. Long story short, I think I have a bad bearing in my rearend........
Originally Posted by lostmybeer
I'll grab my impact and smack it a few times.
I missed part of this are you guys talking about Ed?
hey mark, do you have Pipe Plug Sockets? i have had this coolant filter bolted to my truck but cant get the plug off my water pump.... its just a bit smaller than a 3/8s ratchet.
No, I did the bolt grind approach.
Originally Posted by damons
Mark, just to confirm, exit 238, right?
Yes from the north it is exit 238. If anyone needs directions pm me.
Jeff, I was just told by a very reliable source that you definitely not going make it just because you didn't want to drive your other vehicle. Drive up here anyways!!! I won't point and laugh, I'll do it now and get it over with. No worries
I have two ps pulley pullers and will donate one to Mark's tool collection.
That is awesome! Thanks, Tom.
Jeff you can come in anything you want, truck, car, motorcycle, train or plane.
I know Mark, and Tom, and Clay, and Ed, and everyone. I just have a sinking feeling in my guts not knowing for sure what's going on with my truck. I don't have the time to dig into it, it works now. Tamara works 3 blocks away from the house and can use the truck the rest of the work week. I really need to pull the diff cover, I have a sneaking suspicion that it's the pinion bearing, but it sure makes a heck of a popping noise in reverse. Pulled the axles and the outer bearings didn't seem bad.
I'm trying to work something out fellas, but sad to say.........if it does work out.....the smoker will be left at home.
Leave the smoker and come in the Camry. Your fellowship is the important part. If not I understand and support your decision. Heck, we will come to your house to eat.
