Are you pulling the headliner? I did not and I used 1 roll of the material rated for higher temps and about 1 1/3 rolls of the lesser grade. Trying to remember how much of the cloth for cover. Mine is a crew cab.
Just talked with Princess (Andrew) and am twisting his arm to fly out and see everyone again. So if you see him remind him we need a lesson on how to put on I/C boots with a beer in one hand and an impact in the other at 0300.
Not going to pull headliner. Looks like the self adhesive heavy sheets are $90 for 37.5 square feet and the light is $17 for 14 square feet.
Hey Walt, are those tires the Wrangler Duratracs? How do you like them? And what size you running?
Yes Wrangler Duratrac. So far I've put about 10K on them. They seem to be holding up well and are not as noisy as you would expect them to be. The size is 325/65-18
I'm thinking about getting those next time. I hate my Mickey Thompson Baja MTX's. Got them on clearance for $120 each, so good price, but they wear terribly.
Couple of more projects have been added so if you are wanting shop space let me know.
Mark, once I am done with my traction block install I will be doing the rest of my stuff outside. Is there a bench grinder at the shop with a good wheel on it? (for drill sharpening) I plan on being there on Friday in the afternoon
I have a bench grinder, I also have a bit grinder at work if you want to use that.
