putting in a 302
Old Mar 24, 2011 | 09:20 PM
thomc's Avatar
thomc
putting in a 302
I haven't posted in quite a while. I haven't driven my 56 in several months but have decided to get it back on the road . I plan to remove the 472 Cadillac engine and install a '74 model 302 and C4 trans. The truck has a Volare ifs. It currently has a '68 Dodge car rear end, which will be replaced with a 9" Ford I have.I'm now gather up the parts I will need for the 302, which came out of a half-ton two wheel drive pickup. I believe that I need a rear sump oil pan with the Volare suspension. Which exhaust manifolds do I need? Any advice on the swap will be appreciated. Thanks
Old Mar 24, 2011 | 09:28 PM
BBKtech2's Avatar
BBKtech2
You can use the front sump pan with the Volare.
Not because I work here now but because I have used them on several trucks I've built in the past, have a look at BBK Performance's #1515 shorty header for the 86-93 Mustangs. Nice little compact unequal length header.
Old Mar 24, 2011 | 09:32 PM
Old F1's Avatar
Old F1
Well seeing as you are really going for it, …………..no need to stop now, ………its time for ………………….coated headers……………you know that you deserve them!
Old Mar 25, 2011 | 09:50 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I fitted my 49 F-1 with a 302 last summer. Plan on offsetting the engine to the passenger side a little and even then you may need a shorty oil filter unless you relocate it. Your truck is two inches wider than mine so you will have a bit more room at the steering box. I used 65-66 Mustang exhaust manifolds. The front sump oil pan isn't a problem with the Volare...
Old Mar 25, 2011 | 10:07 AM
gdub's Avatar
gdub
I'm putting the 302 /c4 in mine also. Front sump has plenty of clearance, I did set mine about an inch to the passenger side to give more room by the steering box.
Old Mar 25, 2011 | 11:11 PM
carnut122's Avatar
carnut122
I have BBK 1515's on mine too. So far, everything has plenty of clearance.
Corrupt Silence
19
Feb 23, 2011 06:34 PM
junksterjohn
May 25, 2010 10:07 AM
airwick51
Nov 28, 2007 12:38 PM
CharlieLed
21
Oct 24, 2007 12:10 PM
johns54
Aug 17, 2002 03:54 PM
