Valve Cover issue
Old Mar 24, 2011 | 08:25 PM
04gray350's Avatar
04gray350
Valve Cover issue
Notice I am leaking oilon the back side of the driver side. Come to find out its the valve cover gasket leaking so I tried to tighten them but all they did was spin on the back two. I guess they messed them up when they put the new gaskets on. Any ideas how to fix this problem?
Old Mar 24, 2011 | 08:33 PM
High Binder's Avatar
High Binder
DOh! I KaN ReAD
Old Mar 24, 2011 | 08:37 PM
04gray350's Avatar
04gray350
ICP whats that?
Old Mar 24, 2011 | 09:46 PM
cheezit's Avatar
cheezit
man if the bolts are spiining in the aluminum rockerbox your gonna need to do some helicoil work.
iirc 8x1.25
Old Mar 24, 2011 | 10:02 PM
04gray350's Avatar
04gray350
Helicoil work please tell me more. The two on the drivers side front anr good and tight but the back two just spin
Old Mar 24, 2011 | 10:05 PM
cheezit's Avatar
cheezit
how good are you with a drill and tap.
remove v/c ,drill and tap holes incert helicoil (loctite them in with 262) let set for a few min and reinstall valve cover
Old Mar 24, 2011 | 10:15 PM
04gray350's Avatar
04gray350
Is that really soft metal/aluminum that thry screw into?
Old Mar 24, 2011 | 10:20 PM
High Binder
Originally Posted by 04gray350
ICP whats that?
Whoops, I didn't catch the part about the valve cover bolts spinning. It still could be your ICP but the fact that the bolts don't tighten means the threads have been stripped out. If the threads in the head are stripped then you'll have to drill, tap and helicoil the heads but it could be that the bolts themselves have simply stripped which would mean you'd just want to chase the existing threads in the head with a tap and then use new bolts.
Go out and see if you can get the bolts out and see if they have any thread on them. The heads are going to be a little more tricky (i.e. a total bitch due to their location) to drill and tap, helicoils are the easy part...
Old Mar 24, 2011 | 10:28 PM
Unrealo4's Avatar
Unrealo4
Is your ICP on the passangers side front cover? What's the build date of your truck? Prior to 9/23/2003 it could be your ICP.
Old Mar 24, 2011 | 10:34 PM
04gray350's Avatar
04gray350
Its a late 03 motor icp is on front pass side. So not the issue with my leak.
annaleigh
Jun 6, 2017 06:28 AM
davidrozeboom1
May 17, 2017 08:37 PM
mhartiga1
Dec 19, 2016 06:13 PM
ladelld33
Oct 12, 2015 06:53 PM
plgebbia
Mar 26, 2013 06:02 PM
