pictures would be nice
Old Mar 24, 2011 | 08:05 PM
timmyboy76's Avatar
timmyboy76
Sup guys, been tooling around on the truck for a week, and today, just about got it finished up. Last week started the install on my fuel pres, volt and oil press gauges. Got the fuel and volt working, but waiting til next oil change for the oil press to work, along with installing my new coolant and rebuild the oil cooler, also install the new water pump, and tab it, for the coolant temp gauge. Also, "modded" my shifter (zf6) so my gauges and pod will work, under the dash. Ended up welding a rod to the existing "stubby" from the trans, so now, i got the clearance for the gauges. Think it came out sweet. Hopefully, i figure how to download pix and put them into "my gallery" to show off....
Old Mar 24, 2011 | 09:50 PM
clintbonnie's Avatar
clintbonnie
Just click on "User CP" in upper left hand corner of this page.. and then edit gallery.. and following instructions to Create a Album..
Old Mar 24, 2011 | 10:13 PM
woodnthings's Avatar
woodnthings
Why wait for an oil change? You shouldn't hardly any oil (few drops) to install a sender in the different ports.
I installed mine in the HPOP reservoir in lieu of the plug on top. But you can install it in the filter head, or just behind the filter head at the port on the rear of the block.
