4x4 Indicator Light?
Old Mar 17, 2003 | 08:10 AM
Ken2600's Avatar
Ken2600
I saw this on ebay (Item # 2406876931). The item has ended now but this is the first time I had seen/heard of one of these.
Was this a pretty rare option? Is the wiring/switch alread on the T-Case even if you didn't order the optional light or would you have to find the switch/sender if you were going to add this feature to a truck that didn't come with it?
Old Mar 17, 2003 | 08:59 AM
73Custom's Avatar
73Custom
The shoptruck where I work is a '78 F150 4x4 400 auto, it has one mounted under the dash. It doesn't work, I never investigated to see what it was, just thought some PO had it hooked to a stereo or something. Now I'll have to do some digging around...
Marty
Old Mar 17, 2003 | 11:21 AM
rompin78's Avatar
rompin78
I was curious about this to. My buddy has a 4x4 light on his 81' F-150, but there is nothing on my 78' F150 4x4. Does anyone else have one of these light indicators? Or where to get one?
Thanks!
Rompin 78'
Old Mar 17, 2003 | 01:14 PM
petem's Avatar
petem
Hi-
I have one on my '76 F250. Mounts under dash, just right of ashtray. Light comes on when the "lock" position is selected on the 203 transfer case. Originally, I thought there was a switch for the light on the linkage, but a wire is attached to a sensor(i think) on the transfer case itself. Hope that helps!
Old Mar 18, 2003 | 12:34 AM
Superdave's Avatar
Superdave
My Dads old 78 has one on it. And this one still lights up bright blue when you lock it in 4 wheel drive.
This particular setup was only on the fulltime transfercases on the older Fords as mentioned above.
Sam Menard
6.2L V8
20
Aug 25, 2015 01:37 PM
Highboy4x4
1961 - 1963 F100 Unibody
74
Jul 14, 2014 08:20 PM
JHoffman93
Jan 21, 2014 06:43 AM
hemichrysler
17
Jun 15, 2007 11:52 PM
mudduck_25
Nov 12, 2002 12:10 AM
