1978 - 1996 Big Bronco
what can i do?
Old Mar 23, 2011 | 06:22 PM
jetjr1865's Avatar
jetjr1865
what can i do?
can i take a 2wd aod trans 14 bolt pattern from an 89 lariat xlt,remove the tail piece and it go on my 90bronco xlt 4wd t case or do i have to modify or change anything
Old Mar 23, 2011 | 06:35 PM
82_F100_300Six's Avatar
82_F100_300Six
good question, I always wondered about that. if the output shaft is different after you remove the extension housing you will have to pull the tranny apart
Old Mar 24, 2011 | 03:15 AM
greystreak92's Avatar
greystreak92
At the very least you will need to change tail shaft housings. 2WD transmissions have no provision for mounting the transfer case. There may be more issues but thats the first and most prominent that comes to mind.
moverbeck48
Sep 25, 2013 10:58 PM
xdavis22
Jan 11, 2011 04:47 PM
XLT 2WD
Jan 28, 2010 07:38 PM
fast_eddy
22
Dec 25, 2001 02:48 AM
