Sponsored by: Real Truck
Rancho Wireless Controller
Old Mar 23, 2011 | 03:06 PM
MisterCMK's Avatar
MisterCMK
I got my wireless ride controller a couple of weeks back but have yet to install it. Has anybody else installed one of these and what are your thoughts on it?
Old Mar 24, 2011 | 02:42 PM
mwsF250's Avatar
mwsF250
I installed mine a couple weeks ago.
I took the better part of a day to do it, but I am more than a touch AR and took the time to do it really well. Custom brackets to mount controller, no crimp connections, routed hoses really cleanly.
Thoughts:
- Super convenient! Not having to crawl underneath is very nice. Makes me want to get with the program and add remote control to my air bags!
- Works just as they describe.
- Install went fine. No air leaks, no real problems.
- The little air line cutter they provided looks cheesy, but worked very well.
- I used silicone dielectric grease to lightly lube the O-rings and the ends of the air lines before inserting. Worked very well.
- I am still not that impressed with Rancho's approach to damping valving. WAYYY too much (and nowhere near digressive enough) compression damping. Primitive.
- Due to that, using any of their default settings resulted in an unnecessarily harsh ride. So I use only the MyRide setting and adjust them as needed. I was happiest with 0/0 for empty truck, bumped up to 1/3 when travel trailer was hitched up.
Old Mar 25, 2011 | 08:03 AM
edshy's Avatar
edshy
I have the kit to install as well but I want to come up with a system that can use one compressor for everything if possible I allready have one for the airbags. I have been think about maybe using some NOS valves to controll the air.
Old Mar 25, 2011 | 09:06 AM
MisterCMK's Avatar
MisterCMK
Thoughts:
Great, just the feedback I was looking for. Where did you mount the controller on your truck?
Old Mar 25, 2011 | 12:13 PM
Rancho Suspension's Avatar
Rancho Suspension
Former Vendor
mwsF250's write up is really good. Keep the lines smooth and kink free. Enjoy!
Old Mar 25, 2011 | 12:27 PM
mwsF250's Avatar
mwsF250
The compressor and controller are mounted right underneath the air filter canister. A little lower than I really wanted, but it fit quite well. And the existing "residue" down there indicates not much (if any) water gets there when driving in rain. Pretty well shielded by all the stuff around it.
My truck is mildly lifted so the risk of submerging these in a water crossing is still very, very low. It would have to be over 24" of water, and the fan would be slapping water as well. I try to avoid that!
