Sponsored by: Real Truck
Do you guys get flashed a lot?
Old Mar 23, 2011 | 10:39 AM
BCM's Avatar
BCM
I have a 2011 F250 SD 4x4, all stock. I've noticed that the high beams really aren't much higher than the standard beams when activating them, and the high beams really don't light things up the way they did in my 03 EB Expedition. Plus, I get flashed a lot from oncoming vehicles... Is this normal for this truck, or are my headlights aligned too high?
Old Mar 23, 2011 | 10:41 AM
Menghi08LT's Avatar
Menghi08LT
Mines the same way. I figured it's because the truck is so tall to the cars around here that the lights are aimed right at their faces. But my high beams work pretty well, there is some difference. It's a lot brighter with fogs too.
Old Mar 23, 2011 | 10:50 AM
2000silverbullet's Avatar
2000silverbullet
Exact same perception with my truck as well. I think they're aimed too high.. Lost of oncoming traffic hits the brights, and when I do flip the brights on, they're weak. Someone (possibly Epic?) did a video on adjusting the headlights. It might be down in the 6.7 forum.
Old Mar 23, 2011 | 10:51 AM
fz1dave's Avatar
fz1dave
Super Duty
Happens to me a lot. I keep thinking it's because the fog lights are aimed a tad too high. If they're not on, it doesn't happen nearly as often.
Old Mar 23, 2011 | 11:31 AM
bigblue61's Avatar
bigblue61
all the time funny story though gf was driving the truck got flashed so she turned the dial thinking she turned it too far and put the high beams on. So she turned the lights off and got a ticket
Old Mar 23, 2011 | 12:16 PM
smotrs's Avatar
smotrs
Have you checked the alignment of your beams? After I got my truck I checked the alignment myself and they were actually high straight from the factory. Adding my lift made them even worse. After manually adjusting them myself, about the only time I get flashed now is when I have a trailer or heavy load.
Old Mar 23, 2011 | 12:55 PM
BCM's Avatar
BCM
How do I check the alignment?
Old Mar 23, 2011 | 01:19 PM
Menghi08LT's Avatar
Menghi08LT
It's in the owner's manual somewhere... I don't have it in front of me so I can't copy it.
Old Mar 23, 2011 | 01:21 PM
BCM's Avatar
BCM
Ah. Ok. Good. Thanks!
Old Mar 23, 2011 | 11:33 PM
twigsV10's Avatar
twigsV10
I like to find a flat empty road and cover one light at a time and aim the other going from high to low
Old Mar 24, 2011 | 06:27 PM
smotrs's Avatar
smotrs
Taken from the manual,
AIMING THE HEADLAMPS
Your vehicle may be equipped with a sealed beam or aerodynamic headlamp system. Sealed beam headlamps may be aimed in the vertical (up/down) and the horizontal (left/right) directions using the procedures following. The aerodynamic headlamps can only be aimed in the vertical direction (up/down) using the following procedures. The headlamps on your vehicle are properly aimed at the assembly plant and should not normally need adjusting.
Vertical and horizontal aim adjustment (sealed beam headlamps)
The headlamps on your vehicle are intended to be aimed using mechanical aimers. If mechanical aimers are used and the cross-car sight line is in any way blocked, set the legs of the universal adaptor all to the same setting, such that the cross-car sight line is no longer blocked, per the instructions for the brand of mechanical aimer used. You can also aim the headlamps visually using the procedure below.
To adjust the headlamps:
  1. Park your vehicle on a level surface about 25 feet (7.6 meters)
  2. away from a vertical plain surface (3). Check your headlamp alignment at night or in a dark area so that you can see the headlamp beam pattern.
    • (1) 8 feet (2.4 meters)
    • (2) Center height of lamp to ground
    • (3) 25 feet (7.6 meters)
    • (4) Horizontal reference line
    • (5) Center of headlamps
    • (6) Center line of the vehicle
  3. The center of the headlamp is marked either on the lens (a circle or cross marker) or on the bulb shield, internal to the lamp (mark or feature). Measure the height from the center of your headlamp to the ground (2) and mark an 8 foot (2.4 meter) long horizontal line on the wall or screen (1) at this height (masking tape works well).
  4. Turn on the low beam headlamps and open the hood.
  5. Locate the high intensity area of the beam pattern and place the top edge of the intensity zone even with the horizontal reference line (4). If the top edge of the high intensity area is not even with the horizontal line, follow the next step to adjust it.
  6. Locate the vertical adjuster (2) for each headlamp. Adjust the aim by turning the adjuster control either clockwise (to adjust up) or counterclockwise (to adjust down).
  7. In addition to the horizontal line marked in step 2, a pair of vertical lines (5) must be marked at the center line of the headlamps on the wall or screen.
  8. On the wall or screen, locate the high intensity area of the beam pattern. The left edge of the high intensity area should be even with the vertical line corresponding to the headlamp under adjustment. If the left edge of the high intensity area is not even with the vertical line, follow the next step to adjust it.
  9. Locate the horizontal adjuster (1) for each headlamp. Turn it clockwise or counterclockwise, to place the left edge of the high intensity area even with the vertical line corresponding to the headlamp under adjustment.
Vertical aim adjustment (aerodynamic headlamps)
The headlamps on your vehicle can only be vertically adjusted. Your vehicle does not require horizontal aim adjustments.
  1. Park the vehicle directly in front of a wall or screen on a level surface, approximately 25 feet (7.6 meters) away.
  2. Measure the height from the center of your headlamp (indicated by a 3.0 mm circle on the lens) to the ground and mark an 8 foot (2.4 meter) horizontal reference line on the vertical wall or screen at this height (a piece of masking tape works well).
  3. Turn on the low beam headlamps to illuminate the wall or screen and open the hood. Cover one of the headlamps so no light from that lamp hits the wall.
  4. On the wall or screen you will observe a light pattern with a distinct horizontal edge towards the right. If this edge is not at the horizontal reference line, the beam will need to be adjusted so the edge is at the same height as the horizontal reference line.
  5. Locate the vertical adjuster on each headlamp, then use a E5 Torx socket to turn the adjuster either counterclockwise (to adjust down) or clockwise (to adjust up) aligning the upper edge of the light pattern up to the horizontal line.
  6. Repeat Steps 3–5 for the other headlamp.
  7. Close the hood and turn off the lamps.
Old Mar 24, 2011 | 08:42 PM
SuperDutyKing's Avatar
SuperDutyKing
For some reason, oncoming traffic seems attracted to light, they stare at your lights and if the fogs are on it does that much more to attract there attention, just my 2 cents.
Old Mar 24, 2011 | 08:43 PM
BCM's Avatar
BCM
I drove tonight with the fogs off... no one flashed. Tomorrow night I'll be on the road where the flashing is consistent. I'll continue the experiment there.
Old Mar 24, 2011 | 09:06 PM
sundance8's Avatar
sundance8
Driving down I-75 a couple of years ago I got flashed by two girls in a Bronco.
Old Mar 25, 2011 | 07:51 AM
alandeon's Avatar
alandeon
Yeah, I get flashed every morning by my wif.... Oh, you meant in the truck
One thing I noticed about the F250/350's is that because of the front end bounce and the way the lights are verypinpoint in the center, every time one is driving towards me, it looks like THEY are flashing me. It's really because they are bounceing a bit more than the usual vehicle and I see the strongest part of the light more clearly with every bounce, giving me the impression that they are flashing me. (I'm currently driving a F150 waiting for my F250 to arrive so I notice the F250's alot as I dream about mine) It only seems to happen with the Ford though, so it must be the style of light that Ford uses.
