EOT gauge question
Old Mar 22, 2011 | 08:21 PM
fastbee's Avatar
fastbee
EOT gauge question
For those of you running analog gauges, what types of temps are you seeing for EOT and where did you mount your sender? When I got my gauges a little while back I read what seemed like hundreds of posts about sender mounting locations. The consensus seemed to be that an aluminum oil filter cap was the ticket...easy and gave good readings. Well, I think something must be wrong with mine. I had an Insight some time back, so I've got some historical data for comparison. My usual oil temps for my normal driving were 185* ~ 190*, now I only get about 160* with my NUC Motorsports cap. I had an extra sender, so I swapped it in...same thing. Then I moved the gauge in the pod, hooking it to the ECT circuit. The gauge read what the original ECT gauge read, so no problem with the gauge. When I hooked the ECT gauge to the EOT circuit, it would only read the 160* or so. I checked all the wiring and everything seemed fine. I use Racor oil filters that have the hole in the top, and when I remove the cap there is a healthy coating of oil on the inside and on the end of the sending unit. Any ideas as to what could be the problem? Is it the cap? I used teflon tape on the threads...was that wrong? I'm at a loss...BTW, I have done an EGR delete and upgraded oil drain tube since the Insight, but I can't imagine the oil temps changing that much from the delete and tube!
Old Mar 23, 2011 | 04:41 AM
XB70's Avatar
XB70
I can't speak to EOT OEM and aftermarket sender locations, but I did find out about transmission oil temps.
According to Mike Kovelsky, a former Ford transmission engineer, the OEM sender that my Scangauge II reads is in a location 10 - 15F higher than the typical aftermarket sender location on the upper right side of the case. I'm sure it can be a similar situation for any aftermarket sender.
It's not about sender or gauge calibration. It's all about sender location.
This is exactly why I bought a Scangauge II. It reads data from OEM senders. If EOT/ECT delta is supposed to be 15F or less, that's based on temps read from OEM senders in factory locations. Ford service diagnostics are all based on OEM sender data. If your aftermarket senders are in non-stock locations, how are you going know if your EOT/ECT delta is real?
Sure, an ISSPRO gauge is cool to look at and a strong arguement can be made for having a gauge set up completely independent circuit in case the OEM sender and/or gauge fails, but the data obtained from factory senders in factory locations feed the truck's computer to manage your engine.
The "real" temperatures are obtained with your Insight or Scangauge. If you want analog gauges with their own senders, run both and learn the adjustment factor for each gauge.
Old Mar 23, 2011 | 08:35 AM
fastbee's Avatar
fastbee
I don't care about the delta of EOT/ECT...I don't have an EGR cooler anymore. My factory water temp gauge reads the same from about 150* to upwards of 200*, not very reliable, with no oil temp gauge at all. I'm also not necessarily concerned with exactly matching the factory sensors...I know that my ECT sender being mounted on my coolant filter will read a little cooler (about 5* from previous Insight data), but I know that it is close and is giving me reliable, repeatable information. The EOT gauge is not giving me that feeling and I'm just curious what others are seeing from the filter cap installation to try to determine if something is wrong with my setup. I have machined a fitting to allow my EOT sender to replace my oil pressure dummy switch and also have a made a fitting to go in the test port on the front of the oil cooler (both should read the same as factory), but the question is: why is my cap installation reading so different from what others have said they read?
Old Mar 23, 2011 | 10:55 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
I believe that the filter cap location has a problem with cold airflow over the cap. I too, use that location and in winter I could NEVER get the EOT up to anywhere near normal. Summer was also ok. So this past fall, I wrapped the oil filer and sender probe area with a wad of about 4 wraps of insulation and - lo and behold - I was able to get the EOT temp to read correctly ( or closer to correctly anyway). After warmup, my EOT now reads 182-187. I KNOW the temp will get quite a bit higher when I start towing again. I will then be able to watch EOT and ECT's confidently!
Old Mar 23, 2011 | 11:42 AM
fastbee's Avatar
fastbee
That was one of my suspicions...don't know if I want to put the insulation on though. I might just have to move it, maybe I'll use the filter cap for a bypass setup one day.
Old Mar 24, 2011 | 08:05 PM
fastbee's Avatar
fastbee
I tried replacing the teflon tape with black hi-temp RTV...no real change. Even now that the weather is warmer the gauge won't read anymore than 165*.
Old Mar 24, 2011 | 08:26 PM
jdadamsjr's Avatar
jdadamsjr
fyi, the scangauge reading from the obd port seems to get eot and water temps correct....
Old Mar 24, 2011 | 11:11 PM
Headviking's Avatar
Headviking
What kind of insulation did you use? I am having the same problem. Temps never get higher then 150F. Any pic of the insulation.
Old Mar 25, 2011 | 10:15 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
I haven't taken a pic of it, but I can later. ( Working on income tax - yuck) It ain't "pretty", but it works.
Here's two photos: Using 4" Insulation I had laying around....
Old Mar 25, 2011 | 02:18 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
------------- BUMP ------------
Old Mar 25, 2011 | 07:56 PM
fastbee's Avatar
fastbee
No doubt it does...as did my Edge Insight, but that's not what I'm talking about.
Old Mar 26, 2011 | 02:32 AM
XB70's Avatar
XB70
Let's see. I can continue using my Scangauge II for EOT readings or I can put the sender in the wrong place and try to fix it with this:
What are you talking about, fastbee? Your aftermarket sender reports temperatures accurately for the location you decided as a mounting place. If you want the same temps as OBDII, put your sender in the same place as the factory sender.
Old Mar 26, 2011 | 04:20 AM
fastbee's Avatar
fastbee
That's the thing XB70, I don't feel that it is reporting accurately for that location. Perhaps if you would read the post, you would see that said "many" (in excess of a dozen) people are reporting that location is giving them temps that totally agree with either the ScanGauge or Insight. None other than BPofMD have said anything about using insulation. One of the best 6.0 guys I know of, Doug at Direct Injection Performance (PSDPlayer on PSN) recommended the cap location. What I'm talking about, and by the way what no one but BPofMD and Headviking so far on FTE, has given me is what your setup with ANALOG GAUGES ACTUALLY READS. If I wanted to know about ScanGauge, I would have posted about ScanGauge or factory locations or whatever else that didn't relate to my setup and ones like it.
Old Mar 26, 2011 | 04:44 AM
XB70's Avatar
XB70
Borrow a Scangauge or other OBDII reader and run it parallel with your non cotton candy covered oil filter. Then, you'll know 150F is really 164.75F and 180F is really 203.5F, and 193F is really 205.764F..... That's much easier than plugging in a Scangauge.
I'm asking, "Why Dick with it?"
Old Mar 26, 2011 | 03:38 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
You can also get real close to it by pointing a laser temp reader at the water hose....... but- again - that isn't what he was asking..........
BTW, I can't SEE that ugly photo from my drivers seat!!!
