vin #, tranny quesiton
This is the information:
VIN: 1FTDF14E78PB04328
WB:117
TYPE/GVW:F140
BODY:AB4
TRANS:F
AXLE:14
DSO:VY
If anyone can translate any of this stuff, please let me know. I know the axle is the 3.00 open 9". Thanks for all the help.
Dennis (assist admin here) has a place to help decode the rest. Works for most late 70's - very early 80's trucks.
http://www.clubfte.com/users/mil1ion...ruckCodes.html
Hope it helps.
Edit-The transfer case isn't going to be listed on either the VIN or the door jamb sticker. You'll need to crawl underneath and do some investigating. NP's have a stamp on them and mine had a round label plate with the model number stamped on it: NP 208 F.
-Kerry
D - 5-6Kip brakes/GVWR
F - pickup
1 - 1/2-ton chassis
4 - probably 4WD (any even number here indicates 4WD)
E - 302ci HO
7 - check digit (meaningless)
8 - actually "B" - 1981
P - St. Paul, MN
B04328 - serial number
WB:117 - wheelbase in inches
TYPE/GVW:F140 - (repeats previous info): 1/2-ton pickup 4WD light axle
BODY:AB4 - blue vinyl seats; fleetside bed
TRANS:F - BW T-19
AXLE:14 - Ford 9" open diff 3.00 ratio 3750lb
DSO:VY - (dunno - doesn't look like a DSO code)
E-mail me (not PrivMes) if you want a copy of the VIN decoding documents I have. '83 & '02 ~500Kb together.
