Sponsored by: Real Truck
WHAT size TIRES?
Old Mar 22, 2011 | 10:35 AM
Dxtryng's Avatar
Dxtryng
WHAT size TIRES?
what all terrain tires would you recommend? it says on the site for my leveling kit i can fit a 33x12.5 also any recommendations on some nice cheap simple crome rims?
Old Mar 22, 2011 | 10:37 AM
Dxtryng's Avatar
Dxtryng
also how small of a rim can i fit on my truck, its a 04 f250 xlt 4x4
Old Mar 22, 2011 | 11:28 AM
Bigpipes 35's Avatar
Bigpipes 35
Fitting 33/12.5 should be no problem as far as rim size you cant go any smaller than the stock ones. I have Eagle alloys on mine seems to be a good wheel and not to expensive.
Old Mar 22, 2011 | 12:34 PM
dkf's Avatar
dkf
The BFG A/T is very good All Terrain tire. They are not the cheapest but they are good tires. As for the wheels you don't want to go any smaller than 16". If it were me I would go with some 16"x8" wheels. Satay away from American Racing chrome plated Baja wheels. I have a set on my other truck and the chrome peeled off them and the finish is crap. Considering how much these trucks weigh and what they expected to do I would not cheap out on wheels, get a wheel that has a hefty weight rating, obviously a forged wheel is best. Stock wheels are strong and can be gotten cheap but they are on the narrow side for the tires you want to run. (16"x7")
Old Mar 22, 2011 | 04:43 PM
Dxtryng's Avatar
Dxtryng
i was told its cheaper to buy a tire as a 33" compaired to a 285/?/? and i found the bfg all terrain you spoke of in a 33 only question i have is do they make it on a 16-17 rim bc all im finding for what you recommended is in a 15....also how do i know what gear i should have to support a 285 or 33 tire?
Old Mar 22, 2011 | 06:18 PM
dkf's Avatar
dkf
If you want a 33" diameter tire with a 12.5" section width you will need a LT305/70R16. The tire marked as 33x12.5R15 is a C rated tire which is NOT the proper tire to handle the weight of the SD. The LT305/70R16E BFG A/T has a diameter of 33" and a section width of 12.2" so it is equivelent in dimensions to the 33x12.5R15 however the 305 is an E rated tire thus it has 10 plys and is made to handle the weight of a SD which a C rated tire is not.
The LT28575R16 tire is 33" in diameter but has a section width of 11.5" instead of 12.5". An LT315/75R16 tire is also offered however that tire is around 35" in diameter with a 12.5" section width. I have a set of 285/75R16 tires on my stock height 04' SD with stock wheels and they fit very well.
Tim Young
6.7L Power Stroke Diesel
28
Nov 11, 2023 09:21 PM
Alnotch
6.4L Power Stroke Diesel
Jan 3, 2015 10:56 PM
Raptor1.2012
Jul 5, 2013 11:53 AM
Beefford
2004 - 2008 F150
Mar 19, 2007 05:10 PM
bb_1023
May 28, 2004 12:41 PM
