Overdrive trannys?
Old Mar 21, 2011 | 07:22 PM
hayden238's Avatar
hayden238
Question Overdrive trannys?
What overdrive transmissions will work with my 89 EFI 300 straight 6?
Old Mar 21, 2011 | 07:42 PM
Hitokori's Avatar
Hitokori
zfs542 m50dr2 aod
Old Mar 21, 2011 | 07:47 PM
hayden238's Avatar
hayden238
thanks
Old Mar 21, 2011 | 09:10 PM
Encho's Avatar
Encho
The Southernmost Mod
Hitokori pretty much named them all... i think the E4OD never came with the I6, but you could use it with a stand-alone computer (too much ha$$$le, and the tranny isn't worth it).
Old Mar 23, 2011 | 09:41 PM
6CylBill's Avatar
6CylBill
The 300 did indeed come with the E4OD. My truck came with one. Unless you guys mean a paricular year?
Old Mar 23, 2011 | 10:16 PM
Encho's Avatar
Encho
Nope, i just thought it didn't, so i guess you're correcting me. But it's actually extremely rare, your configuration.
Old Mar 23, 2011 | 10:29 PM
court1100f's Avatar
court1100f
lol not to bust your xxlls Encho but the E4OD was used quite abit on the 300s post 89 hell you could probly get one on one in 89 I think 89s when the E4OD came out here in the U.S. of A.
Edited to add: my 1990 F150 Extended cab with 300Cid Straight 6 EFI Came with the E4OD and a 3.08:1 open Differential Rear Axle for example
Old Mar 23, 2011 | 10:32 PM
court1100f's Avatar
court1100f
Hayden you could hypothetically Buy the E4OD from a Scrap yard along with the ECM for the same year model of truck with that Engine say a 1990 like mine with the straight 6 and E4OD and swap out the transmission and Computer and you'd be golden
Edited to add: the E4OD is Essentially a C6 thats been computerized and had an Over Drive gear added to it. So it should be a good transmission for you but I'd get a newer one I can't remember who but somebody mentioned they made improvements to them. think like the 93-95s or something like that couldn't go with a 96 cause of the introduction of OBD2
Old Mar 23, 2011 | 10:35 PM
court1100f's Avatar
court1100f
Originally Posted by Hitokori
zfs542 m50dr2 aod
Matt I love the paint Scheme on your Truck we had an 86 with the exact same paint job and Red valour(sp) interior it was the XLT Lariat model 302Cid EFI Automatic. Don't know which automatic though wasn't my Truck
Old Mar 23, 2011 | 11:28 PM
Encho's Avatar
Encho
I guess i'm speaking of the local scene then. Here the 300/E4OD was never available, as we did get 2WD Broncos, that were never available in the US.
Old Mar 24, 2011 | 01:10 AM
joshofalltrades's Avatar
joshofalltrades
AFAIK, the AOD was never put behind a 300, although it will bolt up. in a previous discussion of the subject at fordsix.com, it was stated that this is because the 300 puts out more low-speed torque than the AOD is capable of handling
Old Mar 24, 2011 | 07:57 AM
6CylBill's Avatar
6CylBill
Actually Encho, the 300 / E4OD isn't rare at all. It's rarer behind the Five Oh.
You said it's rare around YOU, though, so nevermind. =)
Old Mar 24, 2011 | 08:01 AM
94F15094's Avatar
94F15094
yep........
Kenworth
All Things Towing
Jan 13, 2003 01:50 PM
Sunfire_Stomper
Nov 5, 2002 03:31 PM
Yeti
Aug 28, 2002 10:38 AM
wolfmanagh
Apr 23, 2002 07:53 PM
ladani
1997 - 2003 F150
Jul 12, 2001 03:54 AM
